Ga terug   Modelbouwforum.nl > Te koop aangeboden/gevraagd en SponsorCorner > Te koop > [Te koop] Elektronica
Oud 29 juli 2010, 13:56   #1 (permalink)
Leeftijd: 41
Standaard Spectrum AR700 7kanaals 2,4GHZ
Te koop : Z.G.A.N Spectrum full range 7 kanaals 2,4 GHZ ontvanger >>>>prijs 48,95 incl verzendkosten (ophalen in amsterdam-zuid uiteraard ook mogelijk !)
URL=http://img13.imageshack.us/i/spar7000zonder.jpg/][IMG=http://img13.imageshack.us/img13/5561/spar7000zonder.jpg][/IMG][/URL]
Voor verdere info Mail naar rp_meijer@hotmail.com of bel 06-16256501
Met vriendelijke groet Robert
Overview
The AR7000 combines an internal and remote receiver, offering superior path diversity. The radio system simultaneously transmits on two frequencies, creating dual RF paths. This dual path redundancy, plus the fact each of the two receivers is located in a slightly different location, exposes each to a different RF environment and creates a bulletproof RF link in all conditions. The AR7000 is now Flight Log compatible (SPM9540 sold separately).
Spektrum Flight Log
Key Features
Real-time voltage digital display
Records individual antenna fades
Records frame losses
Records failsafes (holds)
Overview
Spektrum’s optional Flight Log is a unique tool that allows you to view the performance of your radio system like never before. With the revolutionary Flight Log, you can now quickly and easily view the real-time voltage supplied to your receiver, how many fades each internal receiver and remote receiver gets each flight, and if the system received any frame losses or failsafes (holds).
The Flight Log is an optional component that was originally designed for testing, but now it is offered as a handy device that gives you a clear digital readout of your radio performance. The Flight Log is not required, but for complex aircraft, it provides an intuitive analysis of the overall performance of the radio installation. Some of today’s models can be very demanding. The Flight Log ensures confidence that your system is working properly and you have optimized the radio installation.
The Flight Log provides the following information:
System voltage - receiver pack voltage
Antenna fades – represent the loss of a bit of information on that specific antenna. Typically it’s normal to have as many as 50 – 100 antenna fades on any one of the antennas during a flight. If any single antenna experiences over 500 fades in a single flight, the antenna should be repositioned in the aircraft to optimize the RF link.
Frame Loss – represents simultaneous antenna fades on all attached receivers. If the RF link is performing optimally, frame losses per flight should be less than 20.
Hold – a hold occurs when 45 contiguous (one right after the other) frame losses occur. This takes about one second. If a hold occurs during flight, it’s important to re-evaluate the system, moving the antennas to different locations and/or checking to be sure the transmitter and receivers are working correctly.
Features
  • 7 channels
  • Includes patented MultiLink redundant receiver technology
  • Utilizes patented DuaLink dual frequency diversity system
  • Internal and one remote receiver
  • Patent pending ModelMatch prevents flying a model using the wrong model memory (feature does not work with module systems)
  • ServoSync (feature does not work with module systems)
  • Flight Log Compatible
  • SmartSafe failsafe system Specifications
  • Type: AR7000 7-Channel DSM2 Full Range Receiver
  • # of Channels: 7
  • Modulation: DSM2
  • Band: 2.4GHz
  • Length: 47mm
  • Width: 25.3mm
  • Height: 15.8mm
  • Weight: 14 g
  • Voltage Range: 3.5-9.6V
  • Antenna Length: Main Rx: 30mm (2); Remote Rx: 30mm (2)
helicopterRobby is offline   Met citaat reageren
Oud 29 juli 2010, 20:00   #2 (permalink)
Leeftijd: 41
Standaard Spectrum AR7000 2,4 GHZ ontvanger
Top electronica voor een lage prijs, ontvanger is z.g.a.n
Met vriendelijke groet,
Robert Meijer
Oud 29 juli 2010, 21:09   #3 (permalink)
Leon325i's schermafbeelding
Leeftijd: 39
ShowCases
Stuur een bericht via ICQ naar Leon325i Stuur een bericht via MSN naar Leon325i
Plaatje zichtbaar gemaakt
Als je van je hobby je werk maakt, dan werk je heel de dag.
http://www.modelbouwforum.nl/forums/...asabi-900.html
Leon325i is offline   Met citaat reageren
Oud 30 juli 2010, 16:42   #4 (permalink)
Leeftijd: 41
Standaard Ar 7000
Nog steeds Te Koop ! prijs bij afhalen is 42,50 euro bij opsturen 39,98 !
Oud 30 juli 2010, 17:23   #5 (permalink)
hobby's schermafbeelding
Leeftijd: 34
Oorspronkelijk geplaatst door helicopterRobby Bekijk bericht
Ik neem aan dat je het andersom bedoeld Robby.
Prijs ophalen €39.98 en versturen €42.50
Trex450 Pro * DX7 * X-ray XT8 1/8 Monster Mamba 5s 5000 30c
hobby is offline   Met citaat reageren
Oud 31 juli 2010, 08:37   #6 (permalink)
Dag
Bericht via hotmail!
Dag is offline   Met citaat reageren
Oud 31 juli 2010, 10:19   #7 (permalink)
Leeftijd: 41
Standaard Ar 7000
Ja uiteraard Hobby hahahaha
VERKOCHT mag op slot !!!
Oud 31 juli 2010, 10:27   #8 (permalink)
marcelsiggery's schermafbeelding
Leeftijd: 40
Jammer dit Robby
Vooral blijven zweven he
marcelsiggery is offline   Met citaat reageren
HTML-code is Aan
Alle tijden zijn GMT +2. Het is nu 01:15.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ShowCase vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.3.2
no new posts
