Ga terug   Modelbouwforum.nl > Auto's en andere voertuigen (graag duidelijke topic-titels!) > Electro auto's > Electro offroad
Oud 16 oktober 2010, 13:40   #271 (permalink)
melvin_f1's schermafbeelding
Leeftijd: 14
de draag armen zijn dan langer maar je moet zelf upper arms maken maar met een langs stuk draad end en van die kopjes lukt da wel hier de parts list en een tutje
found my next mod i will be doing, it a conversion to the HPI RS4 MT suspension, it widens the truck. i copied the parts list for a wild dagger, so you dont need the front drive shaft parts. i also just ordered an associated 17t motor for some extra speed
Parts Required
• HPI Black Flange Pipe (2 packs). TowerHobbies.com | HPI Black Flange Pipe 3x4.5x5.5" (4)
• HPI Cap Head Screw (2 packs). TowerHobbies.com | HPI Cap Head Screw M3x10 (6)
• HPI Dogbones (2 packs of 2 required). TowerHobbies.com | HPI Dogbones RS4 MT (2)
• HPI Front Axle TowerHobbies.com | HPI Front Axle Silver RS4 MT
• HPI rear Axle TowerHobbies.com | HPI Rear Axle Silver RS4 MT
• HPI Suspension Arm Set (2 packs Required). TowerHobbies.com | HPI Suspension Arm Set RS4 MT
• HPI Upright Set. TowerHobbies.com | HPI Upright Set RS4
• Traxxas Rod Ends. TowerHobbies.com | Traxxas Rod Ends w/Hollow Balls Large Revo (12)
• HPI Rear Hub Set. TowerHobbies.com | HPI Rear Hub Set 2 Degree/1 Degree
• Bearings – 5 x 11 x 4, rubber shielded (you need six of these bearings in total)
• Bearings – 10 x 15 x 4, rubber shielded (you need two of these bearings in total)
• 3mm threaded rod
• 4mm threaded rod
• HPI Screw Shaft. TowerHobbies.com | HPI Screw Shaft 3x27mm (4)
• HPI Ball Black. TowerHobbies.com | HPI 4-40 Ball Black (4)
• HPI Flat Head Screw. TowerHobbies.com | HPI Flat Head Screw 3x12 RS4 Pro (10)
• HPI O Ring. TowerHobbies.com | HPI Silicone O-Ring P-3 Red
• 3mm steel washers (you need 12 in total)
HPI Link:
Front: http://www.hpiracing.com/graphics/in.../n_mt-10v2.jpg
Rear: http://www.hpiracing.com/graphics/in.../n_mt-11v2.jpg
Instructions
1. Remove all stock suspension arms and u joints from the stock gearboxes.
2. Use the stock 3mm U joints to connect the HPI RS4 suspension arm to the mount on the gearbox. You will need 3 x 3mm washers on either side as spacers as the HPI arms are a little short.
3. Assemble the uprights, and wheel supports per the link above for the front and rear.
4. You will need to make some upper arm supports using the 4mm threaded rod, and the Traxxas rod ends.
5. When connecting the upper arm support to the gearbox mount, use the HPI flanges – these flanges pack out the space and make the screws fit
6. Make some steering links using the 3mm threaded rod. I used the stock ends for the steering rod where you connect it onto the servo saver and brass ball end on the steering hub.
7. For the mounting of the shocks, you will need to be creative as you will find you cant use the stock mounts, depending on what shocks you use, in conjunction with what shock towers. I use the GPM towers on mine with EMaxx shocks. I was able to drill some mounting points into the suspension arms and get them mounted ok. The plastic seems strong enough to take the load, but time will tell….
8. Use the 3mm o rings to pack the drive cups. On mine, because I have a “Henry super diff”, the drive cups are slightly smaller than stock. I had to dremel the ends of the dogbones to make them fit.
Overall, the assembly is very easy. Use the links above from the HPI website to aid on the assembly. The only difference between this and the Dagger build is:
• Using the 3mm washers where the arms join the gearbox
• The upper suspension arms that you need to make
• The mounting of the shocks, which you may need to be creative on
• You may have a preference on how to link the steering arms to the steering hubs. I used the stock “tall type” brass balls.
• Mount the arms to the gearboxes using the stock “u” type connectors
word echt one of a kind car
ik heb nog erges de web site vaar er ook plaatjes bij staan en van de tut zelf
http://www.rcuniverse.com/forum/m_66...tm.htm#6642870
heel vett hij heeft ze zelf gemaakt maar ik ben er van tussen
wil kopen
ik weet echt nie welke auto ik wil hebben
Laatst gewijzigd door melvin_f1; 16 oktober 2010 om 13:54
melvin_f1 is offline   Met citaat reageren
Oud 16 oktober 2010, 14:49   #272 (permalink)
robin_phaser4rs's schermafbeelding
Leeftijd: 23
oh is wel gaaf ja. Maar die assen houden het nooit...ik heb gisteren weer een gehard stalen cvd as gebroken. Eigenlijk zou je assen van een 1:8 buggy pas moeten kunnen maken. daar heb ik ook al aan zitten denken maar dan moet je ook andere drivecups enzo. En dat wordt lastig in combinatie met de originele differentielen. Dan zou je ook een 1:8 diff pas moeten maken in het originele wild dagger diff huis....mja daar begin ik voorlopig nog niet aan.
phaser4rs met picco p3 .28, wild dagger customized, sprint2 drift, marui coors melling, samenbaksel van whizzer/stadium thunder, slash 4x4, associated b4, tamiya quickdrive
robin_phaser4rs is offline   Met citaat reageren
Oud 16 oktober 2010, 15:29   #273 (permalink)
Leeftijd: 14
de rs4 mt is een nitro dus je bedoelt dat de dogbones het niet houde
lijkt me wel een brusless van ezrun zal niet veel sterker zijn dan een nitro blokje
of je bedoelt deze
wil kopen
Oud 16 oktober 2010, 16:02   #274 (permalink)
Leeftijd: 23
zowel de assen als de cups houden het niet. weet ik zeker
Oud 16 oktober 2010, 16:10   #275 (permalink)
Leeftijd: 14
moeilijk om te kunne zeggen of ik het nog wel zou doen want meer spoorbrete is wel beter en met de brushless ben ik elke maan toch wel minstens 10e kwijt
wil kopen
Oud 26 februari 2011, 15:27   #276 (permalink)
Leeftijd: 42
*Bump*
Vandaag in een actieve bui de alu shocktowers erop gezet. En een beetje aan het rondkijken geweest naar 10 cm lange shocks. Nu ontdekte ik dat de achter-schocks van de Traxxas Slash precies die lengte hebben. Zijn er meer mensen die dit geprobeerd hebben?
TT-01 (drift), Wild Dagger, Baja King, E-zilla (TE KOOP), Grasshopper (een originele!), Traxxas Slash, Xray T3R, 20 jaar oude Wedico Peterbilt & trailer.
Jester is offline   Met citaat reageren
Oud 26 februari 2011, 17:39   #277 (permalink)
Leeftijd: 23
ik zeg...waarom niet?! lekker doen!
ik persoonlijk had een monstertruckje op conrad gekocht en daar heb ik 50-60% van gebruikt waarvan onder andere 10 cm lange shocks.
Binnenkort ga ik van start met een ander project.
Ik ga de wielblokken van mijn slash 4x4 pas maken op mijn wild dagger zodat de assen van de slash gaan passen op de wild dagger. Daarna wil ik een differentieel intern ombouwen zodat het binnenhuis van een revo diff erin past zodat de assen aangesloten kunnen worden. Misschien neem ik dan ook draagarmen van een slash 4x4, maar dat weet ik nog niet.
Oud 27 februari 2011, 13:55   #278 (permalink)
Leeftijd: 42
Even de Slash-shocks getest en ze passen perfect. Ga er meteen maar 4 bestellen.
Oud 23 februari 2012, 18:11   #279 (permalink)
luc-berkers's schermafbeelding
Leeftijd: 16
Standaard tamiya mighty bull ombouwen
ik heb een paar vraagjes over de mighty bull
van tamiya dit is het zelfde onderstel als de
wild dagger overlander etc. kan op dit onderstel een brushless motor
worden ingebouwd, kan het diff dit aan.
en ik zoek nog een tandwiel die op de motor moet worden gemonteerd die ben ik namelijk kwijt weet iemand op welke site ik die kan bestellen op conrad bv ?? ik hoor het wel. hier een paar foto's van mijn auto
luc-berkers is offline   Met citaat reageren
Alle tijden zijn GMT +2. Het is nu 01:41.
