Ga terug   Modelbouwforum.nl > Modelhelikopters > Algemeen heli > FP/coaxiaal
Oud 21 december 2011, 20:28   #1 (permalink)
ExtremeBB
Guest
Berichten: n/a
Standaard Thr
Iemand een link waar ik de heli kan bestellen,
en zo dat ik u'm ook in het weekend bezit ?
Alvast bedankt luitjes..........
groet Ray......
______________________________________________
Update eerste post ,
post ook al je ervaringen met de mSRX in deze thread
De desbetreffende Blade mSRX FBL,
mSR X BNF Basic (BLH3250): Blade - #1 By Design
Key Features
  • AS3X™ Digital Flybarless System
  • High-Precision, Long Throw Linear Cyclic Servos
  • Light Disc Loading and high-performance rotor blade design
  • Caged Tail Motor Mount
  • Coreless main and tail motors
  • Carbon Fiber Tail Boom
  • MLP4DSM 2.4GHz DSM2 4-Channel Transmitter with Batteries
  • E-flite® 1S 3.7V 150mAh 25C Li-Po Battery
  • 1-Cell DC Li-Po Charger included
Overview
Blade raises the bar yet again with the mSR X; the world’s first fixed-pitch ultra micro heli with advanced AS3X™ flybarless stabilization. The core of AS3X technology is a sophisticated, 3-axis digital sensor that stabilizes the rotor head and functions as a heading hold gyro. This, along with its powerful motors and high-precision cyclic servos, gives the mSR X a sense of stability and responsiveness no other fixed-pitch heli its size can match.
Product Specifications
Type: Electric Flybarless Single-Rotor Fixed-Pitch Helicopter Main Rotor Diameter: 7.13 in (181mm) Tail Rotor Diameter: 1.46 in (37mm) Gross Weight: 1.09 oz (31 g) Length: 7.44 in (189mm) Kit/ARF/RTF: RTF Minimum Age Recommendation: 14 years Experience Level: Intermediate Recommended Environment: Indoor/Outdoor Is Assembly Required: No
Hier mijn Blade(s) mCPX , mSR en mSRX naast me kaar,
Uploaded with ImageShack.us
Laatst gewijzigd door Burp; 14 januari 2012 om 09:40
  Met citaat reageren
Oud 21 december 2011, 20:41   #2 (permalink)
REF
REF's schermafbeelding
Je hebt een PB
Gr Rick
E-Sky Belt / CopterX 450 AE V 2/ Blade 120 SR / Spektrum DX6i / Reflex sim.
REF is offline   Met citaat reageren
Oud 21 december 2011, 20:44   #3 (permalink)
ExtremeBB
Guest
Berichten: n/a
Dat was de snelste PB ooit , top man
veel plezier ermee he
Groet Ray.........
  Met citaat reageren
Oud 21 december 2011, 21:11   #4 (permalink)
REF
Graag gedaan hoor, jij sucses en ik hoop voor je dat het lukt.
Gr Rick
Oud 22 december 2011, 13:32   #5 (permalink)
ExtremeBB
Guest
Berichten: n/a
Hey man
ik ook, ik zit nu te wachten op mijn bankpasje die is op kerst shoppen ,
als dat maar goed gaat
moet ik ze toch ff bellen straks, of ze binnen 24u leveren,
of mischien dat jij dat ook weet ~?!
alvast bedankt weer en ik hoop je snel te zien met de mSRX
groet Ray..........
EDIT besteld, nu duimen.........
Laatst gewijzigd door ExtremeBB; 22 december 2011 om 14:59
  Met citaat reageren
Oud 23 december 2011, 21:48   #6 (permalink)
Seaquest's schermafbeelding
Ik heb vandaag mijn mSR X (BNF) opgehaald. Behoorlijk rap dat kleine ding.....
Ik doe hooverend 6 min met een accu. Ik ga voor in de woonkamer nog maar even een paar andere throttle curves proberen, en wat expo. Op mijn settings van de 120SR is hij wel te besturen, maar kijken naar de stick en hij is aan de andere kant van de kamer. Kan natuurlijk ook zijn dat mijn woonkamer te klein is.
Blade mSR X & Blade 120 SR & mcpX (allen DX6i controlled)| Trex 500 | Logo 500SE |T8FG Super
Seaquest is offline   Met citaat reageren
Oud 23 december 2011, 22:45   #7 (permalink)
ExtremeBB
Guest
Berichten: n/a
Aa mooi man , ik zit nog te duimen dat ik de mSRX morgen binnen krijg,
ik weet dat de mSRX gisteren verstuurd is, maar ja kerst is druk dus kan zijn dat ik iets langer moet wachten....
veel plezier met die van jou
Groet Ray....
  Met citaat reageren
Oud 23 december 2011, 22:51   #8 (permalink)
Oorspronkelijk geplaatst door ExtremeBB Bekijk bericht
Groet Ray....
Thanx! Gaat vast goed komen.
Misschien valt het bij de pakketdienst mee met de drukte.
Ik duim met je mee, misschien dat het helpt!
grtz Erik
Oud 25 december 2011, 12:31   #9 (permalink)
R.Obdam's schermafbeelding
Leeftijd: 51
Ik heb hem ook inmiddels mogen proberen,het is wel heel wat anders dan de gewone msr hoor
Mijn accu 160 trekt het niet langer dan 4 min, maar nieuwe zijn onderweg
Heb alleen een vraagje wanneer ik hoover, hangt hij keurig stabiel in de lucht
maar wanneer ik alleen maar rudder geef zowel links als rechts gaat hij aan de haal
pirouettes draaien lukt dus niet
Hebben jullie daar ook last van, nog liever hebben jullie dat kunnen oplossen.
Gr Richard
R.Obdam is offline   Met citaat reageren
Oud 25 december 2011, 22:41   #10 (permalink)
Klopt. Ik heb precies hetzelfde. Bij links of rechts rudder dan reageert ie meteen met de cyclic. Ik ben er nog niet achter hoe ik dat moet oplossen.
Maak jij gebruik van de bijgeleverde zender? Of heb je een BNF?
mvg,
Erik
Oud 26 december 2011, 13:48   #11 (permalink)
Leeftijd: 51
Hoi Erik
Ik vlieg met een BNF op een dx8 zender
Vanalles geprobeerd heli en arco mode expo enz enz
Wanneer ik hem half gas in mijn hand hou,en uitslag rudder geef zie ik geen beweging op de tuimelschijf
Eenmaal hooverend dwijlt hij alle kanten op
Gr Richard
Oud 26 december 2011, 23:09   #12 (permalink)
Richard,
Kijk hier even naar. Bij post #39 staat een pdf met settings voor een dx6i, maar misschien kan jij er er ook wat mee.
Ik heb deze settings nog niet geprobeerd. Zag het net pas staan.
Grtz Erik
Oud 27 december 2011, 00:20   #13 (permalink)
Leeftijd: 49
Hi Richard, ik heb het ook sinds een dag of twee. Eerste lipo vloog de mijne ook als een varken... Totdat ik me herinnerde dat je de heli stil moet horizontaal moet houden als je de lipo plaatst. De gyro's moeten zich even kalibreren, dat duurt een seconde of twee. En toen vloog ie strak.
Dus heli op tafel, lipo aansluiten, even wachten tot het blauwe lampje constant brand, daarna lipo in houder schuiven.
Wat jij omschrijft met de pirouettes daar heb/had ik ook last van. Heli schiet naar voren.
Heb nu twee mixen: het is al beter, maar kan volgens mij nog strakker.
mix1 rub>ail -40 10
mix2 rud>ele -25 -25
D-R rudder 125 125
exp rudder 5 5
vergeten... mijn hyperion's 160mah gaan 4.5 tot 5 minuten mee, in mijn Msr 7 minuten.
Grtz, Frans
FransvH is offline   Met citaat reageren
Oud 28 december 2011, 14:01   #14 (permalink)
ExtremeBB
Guest
Berichten: n/a
Tjone jonge eindelijk binnen
laatste keer dat ik daar besteld heb,
zit ook echt amper wat bij alleen de heli
kon er nou niet een lipo vanaf...
na ja ik heb u'm meer later
Groet Ray.....
  Met citaat reageren
Oud 30 december 2011, 15:35   #15 (permalink)
Leeftijd: 51
Erik en Frans
Bedankt voor de tips, ben helaas niet zo bekend met mijn zender wat mixen betreft wel wat instellingen geprobeerd maar helaas geen resultaat
Heb wel inmiddels mijn beklag hierover gedaan
Dit toestelletje hoort het ook gewoon doen zonder mixen op een eenvoudige zender. Ga er dus vanuit dat de heli gewoon niet in orde is.
Ik verwacht ivm de feestdagen pas volgende week antwoord
Gr. Richard
Alle tijden zijn GMT +2. Het is nu 06:24.
