Oud 8 februari 2010, 20:52   #1 (permalink)
seelanc's schermafbeelding
Leeftijd: 15
Standaard Turnigy 9X 9Ch Transmitter
hey.
wat vinden jullie van deze zender.?
HobbyKing Online R/C Hobby Store : Turnigy 9X 9Ch Transmitter Only (Mode 2) $69.99)
ik wil er een Corona 2.4Ghz JR Module
inzetten: HobbyKing Online R/C Hobby Store : Corona 2.4Ghz JR Module & Rx (V2 DSSS) $45.99)
zou dit kunnen en zijn er ervaringen met de zender en de module.?
seelanc is offline   Met citaat reageren
Oud 8 februari 2010, 21:01   #2 (permalink)
Moderatorteam
Psygho (Emil)'s schermafbeelding
Leeftijd: 32
Even verder kijken, en dan naar onderen scrollen, GEBRUIKERS ervaringen:
Customer Rated
Triton |
sorry, no review but a helpfull manual without watermarks for printerfriendly output.
http://www.mg-ruettenen.ch/files/Tur...ks_removed.pdf
61 people like this review.
Certified Buyer Rated
herb1 |
Dual Rate plus Expo is working perfect. Instruction: After entering D/R&EXP menu, first change D/R setting and second change EXP setting. Please note: Do not change the D/R switch position, when you are in the D/R menu! Then leave menu by pressing MENU button. Then change the D/R swtich position (eg from OFF to ON). Enter the D/R&EXP menu again and change settings beginning from D/R setting and ending by EXP setting. Leave the menu again by pressing MENU button. Finish!
34 people like this review.
Customer Rated
jonlowe |
5 stars, service. Ordered Sat, received Weds to US.
5 stars, look,feel of the 9x. Solid: sticks, knobs, switches are very smooth.
0 stars for the manual. Not included box says to read it! Links for Imax-9x manual exist, but it is not a good manual.
2 stars- acro firmware. Can't do dual rates AND expo at same time (also heli,glid). Ailvator doesn't work, confirmed by others. Fix these for top notch radio. Programs easily.
31 people like this review.
Value for price
rocket |
I got mine yesterday and have been programming and testing. The sticks feel really nice compared to the FlySky. I have never owned a Futaba or Spektrum et. al. I also find it funny the box has a stern warning to read the manual first but doesn't include the manual. I found it online anyway.
To get to both endpoints, you need to move the stick or knob assigned to that endpoint! And/Or assign an AUX channel to that endpoint FIRST (like to a knob)! This frustrated me for some time. The 'simulator port' is much like a headphone jack, not a ps2 type plug. The battery pack looks like it uses the same connector as a 2S lipo with only 2 of the 3 wires connected. You can cut the 8xAA pack and rewire for LiPo's or find a 2S connector and rewire. I cannot close the battery cover with an 1800 mA LiPo.
Once I figure out how to program fully, I think this radio will be a great deal for the price. And the rx's will be affordable so I can get 2 for both 450s I own.
17 people like this review.
Customer Rated
Markus-Ch |
I've seen here
Manual?
http://www.skyrc.us/pdf/imax9x.pdf
13 people like this review.
pizcolq |
Como ya se ha comentado una vez que lo tienes en la mano no da la sensacion de ser una emisora barata. Interruptores y todo muy bien, tacto muy suave, etc. Sin embargo parece que tiene muchos bugs. Creo que lo minimo que deberia hacer HK/Turnigy es testar un producto antes de venderlo, por muy barato que sea.
Customer Rated
Customer |
From what I can see, this is a Imax 2.4 that Turnigy/Hobbycity have branded for themselves. Look at the review for the Imax (just the remote, not the transmitter and receiver) and decide for yourself:
Review: FlySky, Turnigy, iMax 9X 2.4GHz radio control set
10 people like this review.
Customer Rated
dantoni@telusplanet.net |
I am using an ASSAN hacker modulewith the 9X Tx.
With no recievers available I hooked up the Hacker as follows:
1- Top Pin signal
2- no connection
3- Red +
4- Black -
5- no connection.
You can see photo's at Picasa Web Albums - Ed - Turnegy 9X
I only gave it 4 stars as the TX did not work as recieved, one of the wires to the dual rate switch was not connected, an easy fix.
Customer Rated
mayday |
TESTED & APPROVED! awesome range! I will make a blog a.s.a.p for setting "ELEVON" - for foamy using 2 servos and throtle channel only. No instruction but if you are familiar with other brand name radios it takes few moments to figure it out. The user interface menu is self explanatory. Face swithces should be on "UP" pos. and top swithces should be on "DOWN" pos. to avoid "SWITCH ERROR" during start up.
9 people like this review.
HW 5 Stars, SW 2 Stars
Richard Mrazek |
Hardware is super, for this price unbelieveble. But in Firmware is many bugs, I believe, that in later version will be this repaired. But this bugs are not fatal for basic+ using, you only can't use many advanced functions in menu, because this functions are workable in menu, but not in real movement...
Customer Rated
mayday |
Customer Rated
Fitting Assan XJ8 Issue (testing)
Take the module out and hook up the positive and negative leads to a 9 volt battery.
There are 5 connections on the module.
The center pin is positive (+)
The negative lead the next one below. (second hole from the bottom).
LED should remain steady red. If it doesn't the module is faulty.
Customer Rated
Customer |
Great Transmitter anyway. Trying to deal with many-many functions - it's look like expensive TX but for unbeliveable price!!!
DR+EXPO works good.Great Price I like the products Turnigy !
Customer Rated
Randy |
I bought this radio and really like the way it setsup for heli. For the price it is a great buy.
Make sure all the swithes are up when you turn it on or you will get the switch error on display. I would definitely recomend this to someone who doesnt want to spend alot for a 9 channel transmitter yet still get some quality.
Customer Rated
Malfamartin |
Quote:"who guarantees that mixture of marks and models works well? " You must be kidding NN! If you dont understand how the stuff works, don't holler! A PPM signal is a PPM signal no matter what. Not complete? It is actually an advantage to have the possibility to make a choice of modules. 6 Stars for sure
2 people like this review.
durtbag |
Looks nice, sticks have a nice smooth feel. There is no ratcheting feel to the throttle. Screen is a bit hard to see. Feels comfy in my hands. No manual, found one online for the imax 9x and seems to have the info I need. Programming doesn't seem like it will be too hard once familiar with it. Be careful, somehow when changing my model type from heli to acro it switched the TX to mode 1 and my plane went to half throttle. I recommend taking the prop off before messing around with the programming. Using the TGY 2.4 module gives me range out farther than I'm comfortable taking my models. I've yet to have a glitch with this although, it was the cause of glitching on a 72 mhz model of my friends until I turned off my TGY TX and RX. Once off his worked normal and mine was turned on again with no further interference to either.
Customer Rated
Customer |
Just received this radio and am really pleased. Haven't used it to fly yet but my worries about craftmanship have been relieved. It is definately worth the $70.
Customer Rated 11/11/2009
Customer |
Great product, works well! I've read great reviews, and now it's finally back in stock. Hopefully this batch is better on the QC...
Customer Rated
Norrad |
I got a chance to use a friends Turnigy 9X this morning and I loved it. It felt great in my hands and the programming was very easy. I mainly fly 6 channel helis and this radio is perfect for them, all my needs are covered and I have channels to spare for goodies that I may add on future scale projects. I love the fact that it is modular and that I can add my own TX module. For the price and features you are really getting a deal.
Customer Rated
helder |
Precisa ser testado antes de ser colacado a venda, pelo que disseram, realmente tem problemas na sua programacao, a fabrica precisa resolver isso, ou melhor, e sua obrigacao, pois aqui nos pagamos e o cliente tem sempre razao. Vamos la Turnigy arrume o que criou!!!!!
Click here to see all reviews
Upload your own video.
Other product movies
BudgetRC Arrow, Turnigy 2204-14T, 2S Rhinos
Rated: 15
jackosmeister
X-3D-BL asctec quad using Turnigy $9 packs
Rated: 6
Quad_Addict
First flight with the Lumifly Lighting system FAA
Rated: 809
Tightturn
Turnigy Servo Tester
Rated: 20
joshuyo
Twin pack charge lead (2x3S)<->6S
Rated: 7
Sangre
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo
Rated: 1
BAE VS MIRAGE
Rated: 4
P-47 EP with Zippy Battery
Rated: 3
Mauricio D
Retract demo
Rated: 4
Tadango
AIRBUS A388 EDF 55mm ENVERGADURA 1900mm
Rated: 25
avelino
Discount PriceLetter
Sign up for our monthly discount PriceLetter.
Get discounts, special offers,
latest item info + more!
Affiliate Link
Traxxas 1/16 E-Revo VXL, 2200Mah Lipo's, Traxxas Stampede VXL, 4000mah hardcase lipo, Axial AX10 Artr Crawler,Novak Goat,Novak 18,5BL motor,1600mah lipo,Hitec hs5645,lots of alu, Multiplex Easy Star, 2200kv BL motor, 30amp BL Plush esc, 2200mah 3s lipo's, Project: "Alu F350 Highlift" Lots updates to come!, TX: T3pk,FC16,MX16 all Assan powered. All Assan RX.
Psygho (Emil) is nu online   Met citaat reageren
Oud 8 februari 2010, 21:08   #3 (permalink)
Leeftijd: 15
had ik al gezien maar ik vroeg me af of er hier mensen zijn die er ervaring mee hebben
Oud 9 februari 2010, 11:51   #4 (permalink)
ralfv
Guest
Berichten: n/a
Hallo,
Ik heb er zo één, met de Corona module.
Het werkt, ongeveer. Dat is ongeveer het enige wat ik erover kan zeggen.
De programmatie is afgrijselijk en de software zit vol fouten.
Wordt gebruikt (maar niet veel) in schuimen hellingzwevertjes.
Mvg,
Ralf
  Met citaat reageren
Oud 9 februari 2010, 17:00   #5 (permalink)
Leeftijd: 15
en wat bedoel je precies met fouten.?
het is dus het geld niet waard.?
Oud 9 februari 2010, 20:22   #6 (permalink)
ralfv
Guest
Berichten: n/a
Hallo,
Butterfly mixer werkt niet goed,
Geen expo en dual rate tegelijk,
Saven waarde of cancel - 50% klik je verkeerd en dan kan je opnieuw beginnen
Stomme typfouten
Mvg,
Ralf
  Met citaat reageren
Oud 10 februari 2010, 17:24   #7 (permalink)
Leeftijd: 15
wat is butterfly mixer.?
en kan je echt niet de expo en dual rate tegelijk gebruiken.?
in de reactie stond namelijk dat dit wel kon.?
en er zijn dus geen positieve punten.?(behalve dat die corona ontvangers niks koste)
http://www.rcmodelreviews.com/imax9x.shtml
wat ik hier lees(mijn engels is niet zo goed)
is dat die radios niet getest worden en het maar afwachten is of je een goed krijgt.
ook zou er geen failsafe op zitten..
Laatst gewijzigd door seelanc; 10 februari 2010 om 17:52
Oud 10 februari 2010, 18:00   #8 (permalink)
Sleurhutje's schermafbeelding
Leeftijd: 40
Weblogartikelen: 2
Let op! De 9X is ineens uit de handel genomen bij Hobby King vanwege de software problemen. Na 4 maanden niets meer vernomen te hebben, is de zender nu weer leverbaar. Dus ongetwijfeld is de software aangepast voor wat betreft het mixing en expo probleem.
Failsafe zit in je ontvanger, niet in je zender. Misschien kiezen voor een Assan module?
Voorspellingen zijn moeilijk, vooral voor de toekomst. Maar voor morgen weet ik het zeker, denk ik...
Pret bij Aeroclub Heemskerk via Twitter
Sleurhutje is nu online   Met citaat reageren
Oud 10 februari 2010, 18:14   #9 (permalink)
Leeftijd: 15
is zal nog even verder zoeken of ze het probleem hebben opgelost.
waarom niet die corona module.?
er staat in ieder geval wel dat het dual rate en expo gelijk kan gebruiken .
Important.
Some customers have found difficulty with the D/R & EXP settings. Please be sure you change D/R first, exit the menu then re-enter the menu to modify the EXP setting.
Modifying them together will reset the D/R.
maar er zijn nog veel meer problemen in de software.
Laatst gewijzigd door seelanc; 10 februari 2010 om 18:25
Oud 10 februari 2010, 22:34   #10 (permalink)
Leeftijd: 15
ja ik bedoelde de corona ontvanger dat die geen failsafe zou hebben.
maar sommige zeggen weer van wel
Oud 10 februari 2010, 22:46   #11 (permalink)
JiB
JiB's schermafbeelding
Ik heb die zender en ik ben er best tevreden over. Het menu is inderdaad best lastig, maar als die moeilijke dingen waar mogelijk bugs in zitten gebruik ik toch niet. Wat mij betreft is ie zijn geld zeker wel waard, voor iets soortgelijks met een merkje er op moet je veel meer betalen en kom je in de val van de economy/luxe modellen. Dit is gewoon een zender waar zo veel mogelijk op zit.
En qua failsafe, tja de meeste ontvangers hebben dat niet. Het zou leuk zijn, maar meestal zit je dan ook gelijk vast aan een duur systeem (zender + ontvanger). rcmodelreviews had laatst een review van een systeem met failsafe, maar die heb ik nog niet te koop gezien. Of gewoon blijven zeuren bij de verkopers, want technisch is het zeker mogelijk, het is alleen een software aanpassing voor de ontvanger...
Tijd voor een andere handtekening...
JiB is nu online   Met citaat reageren
Oud 10 februari 2010, 22:51   #12 (permalink)
Leeftijd: 15
hoe zit het me de accu. of moeten er gewoon batterijen in./
Oud 11 februari 2010, 10:19   #13 (permalink)
ralfv
Guest
Berichten: n/a
[QUOTE=Sleurhutje;1560922]Let op! De 9X is ineens uit de handel genomen bij Hobby King vanwege de software problemen. Na 4 maanden niets meer vernomen te hebben, is de zender nu weer leverbaar. Dus ongetwijfeld is de software aangepast voor wat betreft het mixing en expo probleem.QUOTE]
Aangezien het commentaartje wat DR/EXPO betreft er nog bij staat, zal er aan de software wel niet al te veel veranderd zijn.
Wat de batterij betreft, die zit er niet bij. Ik gebruik 3S1P 1800 mAh FlightPower LIPO packs. Gebruik in geen geval losse batterijen, kies voor een gesoldeerd pakje. 8 NIMH bv.
Wat de module betreft, ik zou net iets meer uitgeven en voor Assan kiezen, de betrouwbaarheid daarvan staat denk ik buiten kijf.
Mvg,
Ralf
  Met citaat reageren
Oud 11 februari 2010, 10:23   #14 (permalink)
robert14's schermafbeelding
Leeftijd: 18
Stuur een bericht via MSN naar robert14
zender kan ik niet veel over zeggen,
de corona module werkt echter prima. nooit problemen mee head. over de grond al 800 meter getest zonder problemen. nog niet verder geweest over de grond. ook in zwevers ed geen problemen met verbinding.
doe mee aan DLG!! www.f3k.nl
odoorner luchtvaartclub: www.flyolc.nl
robert14 is offline   Met citaat reageren
Oud 11 februari 2010, 15:53   #15 (permalink)
Leeftijd: 15
A 2400mAH Lithium Transmitter Battery For Just $10
dit wil ik gebruiken als accu.
maar waarom is die assan module dan betrouwbaarder.?
en waarom geen losse batterijen. in mijn dx5e zitten ook losse batterijen
Laatst gewijzigd door seelanc; 11 februari 2010 om 16:10
Alle tijden zijn GMT +2. Het is nu 01:07.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.2
no new posts
