Ga terug   Modelbouwforum.nl > Scheepsmodelbouw > Werkschepen
Oud 2 mei 2010, 14:05   #16 (permalink)
Ghost 2501's schermafbeelding
Leeftijd: 35
Oorspronkelijk geplaatst door leen.boers Bekijk bericht
Hi Marc.
For Dutch offshore modellers, it's very small scale.
We go for the 1:50 scale,
But even a nice model.
)Of course is blue the best Colours)
gr leen
ha ha ha, i found just how she behaves on the water in the waves today [quack] [quack] crossed the wave of a larger boat and tip TIP tip TIP tip TIP. full of water after sailing with the camera!!
Ghost 2501 is offline   Met citaat reageren
Oud 2 mei 2010, 19:05   #17 (permalink)
Leeftijd: 35
video
http://www.vimeo.com/11397600
taken from the fore deck of the boat, at one point she takes quite a wave.
Oud 4 mei 2010, 18:00   #18 (permalink)
Dikkie's schermafbeelding
Leeftijd: 21
Looks like a very decent model to me, loads of options as well..
Question though, about the paintjob. Will you paint her like she's fresh built, or shall you weather her up with a bit of rust?
Bovenstaande post is uitgebracht onder de by-nc-nd 3.0 NL licentie.
Dikkie is offline   Met citaat reageren
Oud 5 mei 2010, 02:31   #19 (permalink)
Leeftijd: 35
Oorspronkelijk geplaatst door Dikkie Bekijk bericht
hi Dikkie. The model is actually quite small, somewhere in the 1/76th 1/87th ballpark area, and so far smaller than the 1/50th so prevelent in the Dutch modelling scene. she is around 500mm in length and around 150mm in width, pulling 50mm of water. (60mm of water when flooded due to being swamped!)
At some stage i intend on sanding all the paint off and redoing it as I admit now, its rougher than a dog's behind! but the weather hasn't been truly great for spraying as it has to be done outside. For some reason the paint hasn't binded well. same tins as i resprayed Celestia with as well and that ship had no issues. i had a scrap that required some touch up, and the masking took off a MASSIVE area of paint making a 20 min job (was just one colour that needed to be done) end up taking 4 hours! fk!
My skills in weathering are not wonderful, so I'll probably keep it newish, right now she has 2 slightly different shades of red, the base coat red and the red used in touch ups.
Laatst gewijzigd door Ghost 2501; 5 mei 2010 om 02:36
Oud 15 mei 2010, 18:38   #20 (permalink)
Leeftijd: 35
due to being swamped more than once, I have decided to make some changes to the interior layout of Nord Adiemus, the older 3300mah 6-cell battery has been pulled out and replaced by a 6-cell AA pack, sitting on top of some polystyrene to keep it out of water.
next plan is to put the entire engine section in an encasement to keep water from getting to it. 15mm to 20mm of water in the boat is not fun!
Oud 16 mei 2010, 20:17   #21 (permalink)
Leeftijd: 35
A change of plan, rather than have the AA pack mounted 15mm off the floor of the boat, sitting on packing foam, I have put the original battery in a tub with a splash cover over it.
The Rx, a Futaba R114F is also located in its on protective case. though i have not tested the battery tub in anger, the Rx case came in handy last weekend after a good swamping.
her hull is filled with strofoam packing as well
Oud 23 mei 2010, 22:04   #22 (permalink)
Leeftijd: 35
from the bridge
Westport Lake May 23 2010 aboard Nord Adiemus on Vimeo
Oud 30 mei 2010, 21:38   #23 (permalink)
Leeftijd: 35
well after several swampings, I have decided to try something, adding plates to the sides of the safety rails, the idea of these is to *try* and prevent water getting into the boat when it gets onto the sides of the deck. Next it may be have work onto the stern section, at regatta, (modelboatmayhem 2010), the winds blew MY table over onto Nord Adiemus, and i think something on the table is what punched a small gash into the hull where the deck and hull meet.
Laatst gewijzigd door Ghost 2501; 30 mei 2010 om 21:42
Oud 30 mei 2010, 23:52   #24 (permalink)
Tinus-online's schermafbeelding
Leeftijd: 30
why aren't you using a receiver/ESC with BEC ?
you won't need the receiverbattery anymore.
btw, with those plates, any water that will make it on your ship will stay there longer, so the chance that the water gets in your ship is bigger.
many people use ducktape to seal the hatch, i guess it works
Tinus-online . nl :: EOS 5D :: Corolla G6 :: mijn bootje
Tinus-online is offline   Met citaat reageren
Oud 31 mei 2010, 00:24   #25 (permalink)
Leeftijd: 35
that battery IS the main drive battery, not the aux batt, the blue you see is just styrofoam bouyancy with a servo lead taped taped to it to keep it from fouling on the linkage for the rudder. this boat is said to be ballasted with polystyrene!!
The idea of the plates are there to stop water getting to the hatch area, like building up the sides of the hull, i also have 4 more holes to drill in the deck hatch and flange, so i can then fit M3 nuts behind them, and so SCREW the hatch down, there is also planking to go on as well, so with the grease i have, the hatch can be hopefully sealed. Water sometimes gets sweped over the low sides of the hull, and its THAT water that i want to stop.
The deck planking will eventually go all the way down the hull to the rollers at the stern.
Laatst gewijzigd door Ghost 2501; 31 mei 2010 om 00:28
Oud 1 juni 2010, 16:40   #26 (permalink)
Leeftijd: 35
Standaard before i go any further.....
it was mentioned about a false hatch...
well here is my idea and interpretation of the mentioning, I have only however done just a mock up, with the piece under the bridge being a final piece, the longer piece is just some scrap.
when complete, the inner flange will go all around the hatchspace and be reinforced. the inner hatch will then sit on this and have tape over the join or grease under the hatch, or even both it to seal it. the external visible hatch will be held in place by screws and eventually planked.
Laatst gewijzigd door Ghost 2501; 1 juni 2010 om 16:43
Oud 1 juni 2010, 23:06   #27 (permalink)
Leeftijd: 30
Oorspronkelijk geplaatst door Ghost 2501 Bekijk bericht
...Water sometimes gets sweped over the low sides of the hull, and its THAT water that i want to stop.
i understand, but the easyest way is to get rid of that water as fast as possible, when the side's of your deck are open, water might get on the deck a little bit faster, but is also flows off the deck really fast.
sealing your hatch is alway good, better then sinking anyway.
Oud 2 juni 2010, 00:10   #28 (permalink)
Leeftijd: 35
so i am building a second hatch, to be sealed with tape to allow easy access, extra sealing will be grease
Oud 3 juni 2010, 00:16   #29 (permalink)
Leeftijd: 35
well letting the glue dry.
the top hatch has yet to have its holes drilled.
Oud 5 juni 2010, 01:14   #30 (permalink)
Leeftijd: 35
well, it sort of worked. after taping the hatch up, i filled the bath up with around 5" of water and put nord adiemus into water up to her roof. no air bubbles escaped from the aft end of the vessel, BUT water, around 120ml, did find its way into the hull. now my eyes will turn towards the bow and where the hawse pipes were put. as they were done post build, they are just CA'd in, so a good mix of epoxy should cure that.
Alle tijden zijn GMT +2. Het is nu 18:08.
