| | #1 (permalink) |
| Lid sinds: 3 januari 2010 Locatie: Stoke on trent Leeftijd: 35
hello, first time on these boards, but i thaught i'd share one of my latest builds with you, her build started at a model boat show, I was board, as it was a small show, and had spotted the model in a plastic bag, and at the price of £30, which was i think around 35euros. I spent most of saturday at the show cutting the hull's excess plastic off, and getting the superstructure made up, rather than using the same superstructure that came with the kit, i chose to build my own one. ![]() inside her, there is a block layout 7.2v ni-mh battery, around 3300mah i think which feeds a 15A Mtroniks Viper speed controller. Initially the choice of motor was a 385, however due to the motor not being in best oc conditions, spinning the 40mm prop, the motor began to overheat, so this was changed to a Graupner speed400 ![]() however the motor still wasn't upto the job, problem was the prop was a little bit too big for the motor, so the result was a drop to a 30mm prop and yet another motor, a new 385... Laatst gewijzigd door Ghost 2501; 3 januari 2010 om 01:59 |
| | #2 (permalink) |
...the new propeller and 385 combination runs much cooler, and even though the rudder i chose may not be the biggest rudder, it handles well, even though for some reason it somehow set at a slight angle and isnt truly vertical, this is the original prop ![]() as you can probably see, its a little large for a tiny motor! things yet to be installed at this time are the anchors and chains, along with the winch gear, they were not in the kit. underway Laatst gewijzigd door Ghost 2501; 3 januari 2010 om 01:46 |
| | #3 (permalink) |
a youtube video YouTube - nord adiemus maiden |
| | #4 (permalink) |
Nice boat m8, good to see some international posters here. The boating forum is really a treasurse of information, even if your english the pictures will tell the tale.
__________________ Ik moet dit is bijwerken^^ |
| | #6 (permalink) |
| Lid sinds: 7 oktober 2007 Locatie: Zandvoort Leeftijd: 19
Try this: ![]() ![]() ![]() ![]() ![]() Just remove th. in your link. http://img94.imageshack.us/img94/4716/pict0662.th.jpg Nice boat. Greetz, Bart
__________________ Varend Maasbank (1:50). In aanbouw Smit Elbe (1:50), Smit New York (1:50) Lid Vaargroep VicWijs |
| | #7 (permalink) |
thanks bart, its the old HFM-Jotika kit, sails well, and given that we had some powerful winds recently that were blowing trees down, she actually sailed quite well, wind has not got much to bite onto in the same way that a Graupner neptun or Sydney star has. Her only access is the aft hatch, so after seeing someone ROLL and capsize an aziz I took the idea to go not quite so scale and use m3 pins with a nut under the deck in order to fasten the back hatch down. rather loose points in a competition than the boat to the lake. other things such as bulwark braces will be fitted in due course, she's not anywhere near done yet. a second youtube video of her http://www.youtube.com/watch?v=zQeHb9KvPYs One thing I did not mention was the radio, I have chosen to keep with my Futaba 6EXA radio on 40mhz, the boat has an R114F inside her, and set up for single stick operation. Laatst gewijzigd door Ghost 2501; 3 januari 2010 om 02:02 |
| | #8 (permalink) | |
| Citaat:
| | #11 (permalink) |
Witch kit is this? It looks very well. Greetz, Bart
| | #12 (permalink) | |
| Citaat:
Its the old HFM Marine ORSV kit, for a while made by Jotika, however i think speedline models may well be reproducing it, Adrian of speedline asked me for feedback as I put the boat together. My main gripe is rudder access, i cut the hatches as per isntructions, and fund that my allen keys (standard metric) would not reach the rudder, so had to cut a second access point in the aft deck. sails brilliantly, if a little duck like compared to some of the heavier 1/50th stuff when in heavy water. there is also a slightly larger wooden versio out made by PBM, not sure if its sold as "weather class" or as "forties shore" Laatst gewijzigd door Ghost 2501; 4 januari 2010 om 00:26 | |
| | #14 (permalink) |
new mast ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Laatst gewijzigd door Ghost 2501; 1 mei 2010 om 15:02 |
