https://myfirstdrone.com/blog/ma ... -everything-we-know DJI Mavic 2 Drone Specs DJI Mavic Pro 2 release date 2018 is now rumored to be late July or possibly August. Mass production began in early February DJI Mavic Pro 2 price will be at least $1299 USD, maybe more. They will also offer “The FlyMore combo” which will obviously be more expensive. The Mavic 2 will be substantially larger Its official name is possibly “Mavic 2 Pro” 4820 mAh battery capacity and 15.2 V power (larger and more powerful than the current Mavic Pro) The battery design itself will be completely different and not compatible with older Mavics Longer flight time—rumored at 32 minutes—Mavic Pro is 27 minutes and Platinum will be 30 minutes. “Quiet” propellers Improved agility and precision Larger motors will bring upgraded propulsion Top speed is 45 mph (72 kph) in sport mode New and improved remote control similar to old Mavic Pro but better Will use OcuSync Video transmission frequency is still a mystery The Mavic 2 will be controlled with the DJI GO 4 app as well Obstacle avoidance in all directions, 6 total including on top of the drone Infrared 3D sensing to avoid obstacles even in the dark An improved vision processing system, faster than Mavic Air Binocular rear vision obstacle avoidance sensors DJI Mavic 2 Camera Specs 12 MP Sony IMX226 CMOS 1/1.7″ sensor (current Mavic Pro has 1/2.3” CMOS sensor) with 28mm (now 24mm) lens 4K video at 60FPS H.265 video format Faster bitrate (100 Mbps) Better low light performance A sharper lens with less distortion Better dynamic range Less Noise 8.8mm lens which provides a 24mm field of view Variable aperture of f/2.8-11 No mechanical shutter Newly designed 3-axis gimbal 'Pro' en 'Zoom' versies. Met termen als 'better, sharper' etc. schieten we niet veel op zonder de exacte specs.
Benieuwd wat het allemaal te bieden gaat hebben. Had ook een topic gevonden met nog meer leaks en de uitgelekte prijzen van de Mavic 2: https://forum.dji.com/thread-161919-1-2.html
Vandaag is de grote dag voor de DJI bekendmaking. Ik hoop stieken op een opvolger van de geweldige Mavic Air 2. Ben benieuwd.
Op YT is een review van Casey Neistat te vinden. Niet echt super maar hij vergelijkt wel alle Mavics' en de Spark. Persoonlijk ben ik een Hasselbladfan, maar die zoomfunctie is op de 'zoom' is geweldig. Keuzes, keuzes........
Heb hem sinds gisteren binnen en even snel gevlogen. Echt super! Wel even oppassen met IMU kalibreren. De afbeeldingen van volgorde klopt niet. Volgende volgens YouTube aanhouden is mijn advies. En niet kijken naar de afbeeldingen op de DJI Go app. En eerst updaten!! Gimbal houder/bescherming verwijderen is even oefenen. Morgen ochtend een paar mooie vluchten maken. Ben benieuwd!
Vandaag super gevlogen. Echt geweldig. Wat een stuk techniek. Ook erg leuk en makkelijk zijn de powerleds onderaan voor het landen in schemering of in het donker. Foto's en Film volgen vanavond. Eerst even gezellig met de vrouw op pad.
Vanmorgen dan eindelijk wat langer kunnen vliegen. Wat een fantastisch goede vliegeigenschappen heeft de Mavic 2 Wonderbaarlijk hoe weinig geluid hij maakt. Met de Sport stand gaat hij bijna naar de 75 km per uur. Heb nog niet alle flight modus mogelijkheden geprobeerd, maar deze week is het goed weer dus dat komt nog. Wel even wennen dat er achterop ook een sensor zit. Bij lading en benadering van achteren gaat deze gelijk piepen. Dat was ook het geval bij een test hoover/vlucht in de tuin, op alles wat is de buurt was reageerde hij meteen. Vd week ga ik mijn DJI Goggles RE koppelen en ben ik heel erg benieuwd naar de full HD beelden in de bril. Op de lader zit trouwens een verborgen Micro USB kabel om de zender op te laden. Foto en Film volgen zo direct.
Hierbij de link naar mijn eerste "rustige" test film. Alles standaard volgens fabrieksinstelling. En hier een test film met een wat snellere vlucht. Gelukkig zit er standaard 8 Gb intern geheugen in de Mavic 2. Heb namelijk mij micro SD kaartje nog niet binnen. Je kunt heel makkelijk via USB kabel de foto's en filmpjes van de Mavic 2 downloaden. De Power Leds bij het landen in het donker is ook super makkelijk Gewicht is 914 gram Wat best veel is en zwaar aanvoelt. Eerste gemaakt foto
