hallo allemaal Ik heb een raptor 50 met de volgende servo`s rol en nick futaba 9252 pitch 9206 (fabriek geef op 4.8 volt only ) batt nimh 2500 deze is 5.8 volt als volledig geladen dus ook bijna 6 volt . Wil met lipo 7.4 volt met een 6 volt limiter er tussen gaan gebruiken. Mijn vraag kunnen de servo`s wel constant 6 volt hebben ? Groet Arie
Wanneer je de Robbe 6 volt limiter gebruikt (de 1-8476), deze regelt de spanning terug naar 5,7 volt: The robbe 6 Volt Limiter derives a stabilised voltage of 5.7 Volts from a 5-cell NC / NiMH battery or two Lithium cells.The maximum continuous load is 5 Amps, but the peak is significantly higher. A constant voltage supply offers the advantage that the servos always deliver consistent power and transit speed regardless of battery voltage. With this limiter it is also possible to use servos which are only designed for use with four NC / NiMH cells. Also suitable for stabilising the voltage of two Li-Po cells (7.4 Volts). In this case the maximum continuous load is reduced to around 3.0 Amps since the unit has to dissipate more waste power. For simple applications one cable to the standard switch harness is all you need. For applications with higher current drain we recommend that you use two cables and a switch harness designed for higher load currents. For example, the 5 A switch harness, No. 8024, or the Safety Switch, No. 8498, which features secure electronic contacts. In this case the second cable is connected to any vacant channel at the receiver. Note: If you wish to connect a second cable it will be necessary to attach a second lead to the receiver battery. Two separate batteries must not be used, as this would bridge the input, causing the batteries to be wired in parallel. De 6 volt benaming is dus niet helemaal juist. Eric.
Even zoeken op discussies met 4,8 en 6 in de titel. Corrien heeft er al veel over geschreven. Kort samengevat: afrader.
Ter verduidelijking: af te raden met 5cellen te vliegen... De oplossing hiervoor is een volt limiter. Deze Robbe limiter brengt de boel terug naar 5,7 volt. Ook mooi als je 2 cellen lipo's wilt gebruiken. Eric.
