HOBAO HYPER 10SC-e
Short Course is now the fastest growing class in RC. Hyper 10SC-e was designed and built to one of the highest quality and standard truck available in the market today. Hyper 10 SC-e is race ready right out of the box so there is no more save up for other option parts. The truck come as RTR package, equipped with brushless motor/ESC and 2.4GHz radio system.
THE PACKAGE
Hobby Wing Brushless Motor and ESC
Equipped with Hobby Wing 3900 KV brushless motor and a 35A ESC to provide plenty and reliable power.
Laser Eteched 7075 Center Universal Drive Shaft
True 7075 aluminum is used on the center universal drive shaft to make sure the shaft is strong enough to withstand instant high torque from the brushless motor.
Multi-Location Shock Towers
The front and rear shock towers features multi shock mounting locations for adjusting different shock setups.
Pivot Ball Suspension
PBS system is also included in this truck to provide easier handling and control
Moulded Battery Box with Ajustable Strap
OTHER SPECIFICATIONS
2.4GHz radio system
Aluminum threaded shock bodies
Front steel CVA
Full ball bearing
Front and rear sway bars
Hard anodized aluminum chassis
Flex tech bumper
EQUIPMENT NEEDED
7.4 LiPo or 7.2 Ni-Mh batteries
Batteries for radio system
DIMENSIONS
Length 533MM
Width 279MM
Height 190MM
Wheelbase 324MM
Weight 2,585G
Servo
http://www.servodatabase.com/servos/all
Hier kun je zien welke servo's, welke specificaties hebben en wat eventueel de prijs is.
SPEED TEST
Nog niet bekend.
MANUAL
Hyper 10SCe Instruction Manual.pdf
http://www.hobao.com.tw/en/images/pro_file/20110302162953@Hyper 10SCe Instruction Manual.pdf
Hyper 10SCe Blank Setup Sheet.pdf
http://www.hobao.com.tw/en/images/pro_file/20110302163213@Hyper 10SCe Blank Setup Sheet.pdf
Hyper 10SCe Exploded View.pdf
http://www.hobao.com.tw/en/images/pro_file/20110302163213@Hyper 10SCe Exploded View.pdf
HOP-UPS
Graphite Front Tower
Part Number: 11056
Graphite Rear Tower
Part Number: 11057
Graphite Center Diff Mount
Part Number: 11058
Graphite Radio Tray
Part Number: 11059
CNC Front Tower
Part Number: 11060
CNC Rear Tower
Part Number: 11061
New F/R Alum Suspension Plate
Part Number: 11062
Alum Front Suspension Brace
Part Number: 11063
Alum Rear Suspension Brace
Part Number: 11064
CNC Light Weight Chassis
Part Number: 11065
CNC Hex Conversion Wheel Hub
Part Number: 11067
54mm Ackerman Rod
Part Number: 11068
52mm Ackerman Rod
Part Number: 11071
Hex Turnbuckle For Rear Upper Arm
Part Number: 11133
CNC Front Upper Arm Holder
Part Number: 11135
Pinion Gears
Part Number:
11051 - 11T
11042 - 12T
11052 - 13T
11036 - 14T
11311 - 15T
11312 - 16T
Other Hop-ups
T-BONE Racing
HoBao Hyper 10SC-Delrin Skid Front- BM-1FA01
HoBao Hyper10SC - Delrin Long Skid rear- BM-1AJ02
HoBao Hyper10SC - Replacement Nylon SC Brace-BM-2AA11
HoBao Hyper10SC-Nylon Basher Front-BM-2BA01
ToadZ RC
STRC Front Steering Upper Plate STO21127GM, Hyper 10SC
STRC Alum. Center Diff. Bulkhead STO21039GM, Hyper 10SC
STRC Alum. Adjust. Battery Plate STO21304GM, Hyper 10SC
STRC HD 5mm Rear Shock Tower STO21122GM, Hyper 10SC
STRC Delrin 42T Center Spur Gear STO21037D, Hyper 10SC
STRC Alu Front Chassis 'H' Brace STO21128GM, Hyper 10SC
STRC Rear Chassis Brace-Mount STO21032GM, Hyper 10SC
STRC HD 5mm Front Shock Tower STO21121GM, Hyper 10SC
TheToyz.com
Jammin Scrt-10 Delrin Front Arms
.jpg)
Jammin Scrt-10 Delrin Rear Arms
Ofna Jammin SCRT10 Rear Shock /Body Tower
Ofna Jammin SCRT10 Front Shock /Body Tower
TIRES
Nog niet bekend.
VIDEO
HOBOA NEWS
Hobao Europe Established
After months of research and preparation, Hobao has finally decided to start our own Europe office in Germany to better serve our customers and drivers and to increase the market share in this competitive continent. Hobao Europe will start its operation by end of February 2011.
HoBao werd eerst door Graupner geleverd. Sinds een aantal maanden word het merk verdeeld door Vader en zoon Scheuenpflug. Zij rijden wedstrijden op een hoog niveau en willen het merk weer op de kaart zetten.
Door de prima kwaliteit en door de zeer korte lijnen met vader & zoon Scheuenfplug is het prettig werken met dit merk.
Om dit merk weer op de kaart te zetten in Europa wilt Hobao-Europe het volgende bewerkstelligen:
* Alle modellen van Hobao zullen op voorraad zijn bij de Nederlanse winkel(s).
* Alle onderdelen van Hobao zullen op voorraad zijn bij de Nederlanse winkel(s).
* In september 2011 is er een bijeenkomst met 20 Nederlandse winkels die interesse hebben in het merk Hobao.
Daarmee is de doelstelling om een stabiel dealer netwerk te creëren voor HoBao in Nederland.
WEBSITE
HOBAO
DEALERS
Op dit moment weet ik niet of er meerdere dealers zijn die ook de Hobao Hyper SC8-e verkopen. Laat me weten als er meerdere winkels zijn, die Hobao Hyper 8SC en aanverwante artikelen op voorraad hebben.
Deze winkels hebben in ieder geval onderdelen op voorraad:
Tilburg:
-http://hobao.nl/
OTHER
Nog wat additionele informatie in het Duits (mocht iemand het willen vertalen voor me, laat het dan even weten!).
Short Course Trucks sind Fahrzeuge die Ihren Großen Brüdern den Trophy Trucks nachempfunden sind, diese erfreuen sich besonders in den USA, aber auch in Europa sehr großer Beliebtheit. Mit dem Hyper 10SC ist der Einstieg in diese Klasse leichter denn je!
Während der Entwicklungsphase wurde mit dem HoBao Factory Team auf verschiedenen Rennstrecken in den USA und Europa getestet um Erfahrung in dieser neuen und aufregenden Klasse zu sammeln, genau aus diesem Grund haben wir ein komplett neues Fahrzeugkonzept entwickelt und es mit drei Öl gefüllte Kegeldifferentiale ausgestattet, um die Kraft auf die zwei Antriebsachsen optimal zu verteilen und eine bessere Traktion zu erhalten, was ebenso dem Fahrverhalten zugute kommt. Um den nötigen Grip auf jedem Untergrund zu erzeugen, liegen unsere speziellen Short Course Reifen mit bei. Es wurde natürlich auch an die Gewichtsverteilung gedacht, um diese optimal auf den Hyper 10SC anzupassen wurden die Komponenten so angeordnet dass, das Gewichtsverhältnis (Vo.-Hi.) in etwa 60% – 40% beträgt. Das Resultat, ein besseres Einlenkverhalten und bessere Kontrolle während der Flugphase, außerdem wird dein Hyper 10SC bei der Landung von fetten 13mm Big Bore Stoßdämpfer unterstützt. Den Antriebsstrang haben wir komplett neu entwickelt, um der Größe entsprechend weniger Verschleiß und eine bessere Beschleunigung zu erhalten. Dieses Modell lässt sich mit original HoBao Tuningteilen sehr leicht Aufrüsten und z.B. für den harten Wettbewerbseinsatz vorbereiten, um deinen Gegnern mal so richtig zu Zeigen wo es lang geht! Durch das Aggressive Karosserie Design besitzt der Hyper 10SC zugleich eine stabile und Aerodynamische Karosserieform was sich ebenfalls positiv auf die Fahreigenschaften auswirkt. Unter der Karosserie verbirgt sich ein spezielles 3-Punkt Überrollbügel System, es sorgt dafür das die Komponenten bei einem Crash nicht beschädigt werden. Wie sollte es auch anders sein, der Hyper 10SC ist durch sein Rennchassis natürlich voll Abstimmbar, egal für welchen Untergrund…
