Hoi, Niet dat ik van plan met om aan te schaffen. Maar deze kwam ik per toeval tegen bij Alibaba 400A ESC AIR 16S LiPo Flier + USB LINK for Airplane Heli Brushless Motor 400A AIR ESC 16S 68V FLIER 400A AIR SERIES UPDATED VERSION HIGH CONTINUOS AMPS: 400A EQUIPPED WITH ANTI-SPARK CABLE INCLUDED USB LINK TO SET IT BY PC FLIER WARRANTY FEATURES Model 400A 16S 68V Airplane series Software and Manual available at Flier Model website The firmware is upgraded recently Firmware can be upgraded by user Motor cable can be inspected while Connecting the power battery Simply set function value by Programming-Box or via PC with USB Link Li-MH/Li-Po,Ne-Cd/Ne-mH,LiFe battery can be use. Enables setting the voltage per cell for the point at which the controller’s cut off circuitry engages. Reverse function. the delay time of reverse is adjustable The power of the motor forward/ reverse can be set. Automatically detection the throttle route or can be set a fixed number by manual operation. Auto cut off the power within 3 seconds if no radio signs. Timing setting may be adjusted (0°-30°) to suit the motor type Until one year limited warranty through Flier factory beginning at date of purchase SPECS Voltage: 4S-16S Battery type: Li-Po, Li-Fe Max continuos amps: 400A Peak amp: 500A Airplane firmware updated Double Wire 8AWG (Input Energy) Programmability via Programming-Box or Link USB (included) Cable anti-spark Cables: 8AWG BEC (No) Wheigt: 462g Size (L*W*H): 125mm x 58mm x 33mm De prijs rond de 233 dollar...
