Productaankondiging KISS Keychain Configurator
Discussie in 'Multicopters electronica' gestart door FedorCommander, 29 okt 2018.
Tags:
  1. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    Hi guys!
    For KISS FC fans, i made this little thingie...
    Specs:
    - 0.96 inch while OLED screen with protection shield
    - 5 way navigation joystick
    - Firmware update via USB mass storage device
    - Super small (28,6mm × 44,1mm × 8mm)
    - Support for ALL KISS FCs
    - Backup up to 10 configurations
    - Full model information including detailed ESC telemetry
    - Full KISS FC Configuration (FC activation is NOT supported)
    - RX and Motor output test tool
    - ESC configuration and test tool (KISS ESCs)
    - 2-5s power input (Will survive 6s, but not recommended)
    - USB charger mode (500mah)
    - LiPo voltage tester
    - USB OTG connector. Host mode with OTG cable for FC connection, client mode for flashing KKC from PC
    USBOTG adapter is NOT included.
    - Real time Gyro spectrum graphs (1.3RC36i required)
    - Serial to USB bridge (for WiFi and Bluetooth extension, can be used with other FCs like BF)
    - Lipo power cut off (safety feature)
    - Support for screen rotation
    If interested, all info on the FB https://www.facebook.com/groups/KissKeychainConfigurator/
    Cheers,
    Alex AKA FedorCommander
    kkc_top_small.jpg kkc_back_small.jpg kkc_angle2_small.jpg kkc_angle_1_small.jpg
