Mijn nieuwe speeltje:
een dagje op de drunense duinen
Kyosho announces the new Inferno VE 1:8th scale brushless powered racing buggy.
The Inferno VE brings you the best of both worlds, Kyoshos legendary world championship quality and Team Orions superior performing Vortex brushless system. This isn`t just a nitro buggy chassis with a motor. This is a brand new buggy platform from the ground up, strategically placed components achieve optimal weight balance and handling characteristics.
The new Inferno VE is offered in a completely ready to go form. All components are pre-assembled, all you have to do is get ready to tear up the competition. The Inferno VE comes equipped with a Team Orion Vortex 8 race spec ESC and motor combo front universals, 17mm wheel hubs, steel centre spur-gear and much much more.
The Vortex 8 brushless motor and ESC combo is what powers the Inferno VE. The Team Orion Vortex 8 race spec ESC is equipped with a cooling fan system, heat protection safe circuit, auto battery detection and a separate, replaceable on/off switch. With is capability to handle 4S LiPo upto 14.8v (2x7.4v) through the 550 size 2040kv brushless motor mind blowing speeds can be achieved. The ESC is also fitted with industry standard Deans style power connectors.
Features:
Team Orion Vortex 8 Motor Specs:
Team Orion Vortex 8 ESC Specs:
Features:
- Fully assembled Readyset package
- Pre-painted super-high air flow buggy body shell
- Perfex KT6 steerwheel RC system
- High torque steering servo
- Team Orion Vortex 8 brushless ESC & motor
- Deans super plugs
- Full-time 4WD with 3 differential transmission
- Die-cast EZ mesh aluminium motor mount
- Heavy duty spiral cut ring/pinion gear
- CNC machined steel main gear
- Anodised alumium oil-filled shocks
- 17mm wheel hex hubs
- Compatible with most Inferno MP7.5 parts
- 550 Size Motor
- 2040 KV
- Continuous Current: 85A
- Peak Currenty: 160A
- Max RPM 60,000
- 5mm Heavy Duty Shaft
- Sensorless
- Cooling Fins
- Sensorless Brushless Only
- Compatible with 6-12 Cells (NiMh) and 2S - 4S (Lipo)
- BEC Voltage 6V
- BEC Current 3A
- Continuous Max Current: 120A
- Peak Current: 160A
- Over Input Voltage Protection (Over 4S)
- Low Voltage Cutoff is programmable (Auto Detect 3.0Vper.Cell)
- Thermal Prtection at 96c
- Dimensions (WxL) 58x47mm
- Weight:108g
