Productaankondiging Mavic 2 Pro
Discussie in 'Multicopters' gestart door Navi-gator, 28 jul 2018.
  1. Navi-gator
    Navi-gator
    23 mrt 2016
    Groene Hart
    https://myfirstdrone.com/blog/ma ... -everything-we-know
    DJI Mavic 2 Drone Specs
    • DJI Mavic Pro 2 release date 2018 is now rumored to be late July or possibly August.
    • Mass production began in early February
    • DJI Mavic Pro 2 price will be at least $1299 USD, maybe more. They will also offer “The FlyMore combo” which will obviously be more expensive.
    • The Mavic 2 will be substantially larger
    • Its official name is possibly “Mavic 2 Pro”
    • 4820 mAh battery capacity and 15.2 V power (larger and more powerful than the current Mavic Pro)
    • The battery design itself will be completely different and not compatible with older Mavics
    • Longer flight time—rumored at 32 minutes—Mavic Pro is 27 minutes and Platinum will be 30 minutes.
    • “Quiet” propellers
    • Improved agility and precision
    • Larger motors will bring upgraded propulsion
    • Top speed is 45 mph (72 kph) in sport mode
    • New and improved remote control similar to old Mavic Pro but better
    • Will use OcuSync
    • Video transmission frequency is still a mystery
    • The Mavic 2 will be controlled with the DJI GO 4 app as well
    • Obstacle avoidance in all directions, 6 total including on top of the drone
    • Infrared 3D sensing to avoid obstacles even in the dark
    • An improved vision processing system, faster than Mavic Air
    • Binocular rear vision obstacle avoidance sensors
    DJI Mavic 2 Camera Specs
    • 12 MP Sony IMX226 CMOS 1/1.7″ sensor (current Mavic Pro has 1/2.3” CMOS sensor) with 28mm (now 24mm) lens
    • 4K video at 60FPS
    • H.265 video format
    • Faster bitrate (100 Mbps)
    • Better low light performance
    • A sharper lens with less distortion
    • Better dynamic range
    • Less Noise
    • 8.8mm lens which provides a 24mm field of view
    • Variable aperture of f/2.8-11
    • No mechanical shutter
    • Newly designed 3-axis gimbal
    'Pro' en 'Zoom' versies. Met termen als 'better, sharper' etc. schieten we niet veel op zonder de exacte specs.
  2. Timcopter
    Timcopter
    3 jun 2015
    Navi-gator vindt dit leuk.
  3. Ralphie
    Ralphie
    1 mei 2016
    Rhoon
    Vandaag is de grote dag voor de DJI bekendmaking.
    Ik hoop stieken op een opvolger van de geweldige Mavic Air 2.
    Ben benieuwd.
  4. Timcopter
    Timcopter
    3 jun 2015
  5. Navi-gator
    Navi-gator
    23 mrt 2016
    Groene Hart
    Op YT is een review van Casey Neistat te vinden. Niet echt super maar hij vergelijkt wel alle Mavics' en de Spark. Persoonlijk ben ik een Hasselbladfan, maar die zoomfunctie is op de 'zoom' is geweldig. Keuzes, keuzes........
  6. Ralphie
    Ralphie
    1 mei 2016
    Rhoon
    Als ze nou een mavic air (=kleiner dan mavic pro) en dan met een zoombare Hasselblad.......
    :thumbsup:
  7. Rhelie
    Rhelie Forum veteraan
    16 sep 2004
    Nootdorp
    Die zal er ook wel komen. Goed bezig daar bij DJI
  8. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Heb hem sinds gisteren binnen en even snel gevlogen. Echt super!
    Wel even oppassen met IMU kalibreren. De afbeeldingen van volgorde klopt niet.
    Volgende volgens YouTube aanhouden is mijn advies. En niet kijken naar de afbeeldingen op de DJI Go app.
    En eerst updaten!!
    Gimbal houder/bescherming verwijderen is even oefenen. Morgen ochtend een paar mooie vluchten maken. Ben benieuwd!
    Laatst bewerkt: 8 sep 2018
    Ralphie vindt dit leuk.
  9. Navi-gator
    Navi-gator
    23 mrt 2016
    Groene Hart
    Hij wordt dus sneller geleverd dan zijn voorganger de Mavic Pro. Benieuwd naar de beelden.
    Ard Schell vindt dit leuk.
  10. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Zal morgen wat beelden plaatsen.
    Ben zelf ook zeer benieuwd.
  11. Ben Jansen
    Ben Jansen
    18 sep 2005
    Dordrecht
    Wij willen foto's zien! :banana:
  12. Rhelie
    16 sep 2004
    Nootdorp
    Ik ben wel erg benieuwd naar je bevindingen en foto`s/ filmpjes.
  13. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Vandaag super gevlogen. Echt geweldig.
    Wat een stuk techniek.
    Ook erg leuk en makkelijk zijn de powerleds onderaan voor het landen in schemering of in het donker.
    Foto's en Film volgen vanavond.
    Eerst even gezellig met de vrouw op pad.
    Laatst bewerkt: 9 sep 2018
  14. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Vanmorgen dan eindelijk wat langer kunnen vliegen.
    Wat een fantastisch goede vliegeigenschappen heeft de Mavic 2
    Wonderbaarlijk hoe weinig geluid hij maakt.
    Met de Sport stand gaat hij bijna naar de 75 km per uur.
    Heb nog niet alle flight modus mogelijkheden geprobeerd, maar deze week is het goed weer dus dat komt nog.
    Wel even wennen dat er achterop ook een sensor zit.
    Bij lading en benadering van achteren gaat deze gelijk piepen.
    Dat was ook het geval bij een test hoover/vlucht in de tuin, op alles wat is de buurt was reageerde hij meteen.
    Vd week ga ik mijn DJI Goggles RE koppelen en ben ik heel erg benieuwd naar de full HD beelden in de bril.
    Op de lader zit trouwens een verborgen Micro USB kabel om de zender op te laden.
    Foto en Film volgen zo direct.
  15. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Hierbij de link naar mijn eerste "rustige" test film.
    Alles standaard volgens fabrieksinstelling.
    En hier een test film met een wat snellere vlucht.
    Gelukkig zit er standaard 8 Gb intern geheugen in de Mavic 2.
    Heb namelijk mij micro SD kaartje nog niet binnen.
    Je kunt heel makkelijk via USB kabel de foto's en filmpjes van de Mavic 2 downloaden.
    De Power Leds bij het landen in het donker is ook super makkelijk
    Gewicht is 914 gram
    Wat best veel is en zwaar aanvoelt.
    Eerste gemaakt foto
  16. Ralphie
    Ralphie
    1 mei 2016
    Rhoon
    Is dat Leo met het witte lange haar?
  17. Ard Schell
    Ard Schell
    20 mei 2009
    Doetinchem
    Nee. Dat is Arold.
  18. Navi-gator
    Navi-gator
    23 mrt 2016
    Groene Hart
    Prima beelden!
