Nieuwe Spektrum DX6
Key Features
  • Ergonomically designed case with comfortable rubber grips
  • Capable of storing 250 models on the transmitter, expandable further by saving on an SD card or PC
  • Direct System Menu Access mean there is no need to power off the transmitter to access all menus
  • Includes Voice Alerts and Wireless trainer out of the box
  • Supports Air/Heli/Sailplane model types
  • Easy to use AirWare software offers the same proven programming found in more expensive radios
  • Smooth, precise Four Bearing Gimbals
  • AR610 6 Channel full range receiver included
  • Programming capability for most sailplanes, can support 4 Sailplane wing types and 3 tail types
  • Supports the most popular Spektrum Telemetry sensors
  • Includes 4 AA Alkaline batteries, optional Lithium Ion battery with charger (available separately)
  • 5 programmable mixes - all mixes are selectable to be normal or 7 point curve multi-point mixes
  • Dual Aileron, Elevon, and V-Tail Differential
  • 7 aircraft wing types and 5 tail types
  • 7 Swashplate types
  • 7-point throttle (air and heli) and pitch curves (heli) Adjustable for smooth throttle and pitch curves
  • Intuitive SimpleScroll™ programming interface
  • Advanced DSMX® technology (DSM2® compatible)
  • SD card slot for updating firmware, expanding memory and sharing setups
  • Activate bind mode from the menu or a button without having to power off
Product Specifications
# of Channels: 6 Modulation: DSM2/DSMX Band: 2.4GHz Receiver: AR610 included Model Memory: 250 Modes: User Selectable Mode 1-4 Transmitter (Tx) Battery Type: 4 AA batteries (Included)
Overview
The Spektrum™ DX6 has been designed from the ground up to deliver way more than you would ever expect from a 6-channel transmitter in its price range.
Programmable Voice Alerts
With voice alerts, the DX6 will allow you to keep tabs on important functions without ever taking your eyes off what you’re flying. They can be programmed to call out what flight mode you’ve chosen or report telemetry information on demand. If an alarm goes off, you won’t have to look at the transmitter display to see what’s happening. The DX6 will tell you.
Wireless Trainer Link
The wireless trainer link gives instructors the option to wirelessly ''buddy box'' with another DSM2®/DSMX® transmitter. Once bound to another transmitter, ModelMatch™ technology will allow the DX6 to re-link without having to go through the bind process again.
Programming for Airplanes, Helicopters and Sailplanes
In addition to its extensive airplane and heli programming, the DX6 includes an impressive list of programming features for sailplanes as well. Five available flight modes, 4 wing types, 3 tail types, a flap-to-elevator curve mix – it has all this and more. The intuitive SimpleScroll™ programming interface makes all of these functions incredibly easy to access and use.
250 Model Memory
The enormous capacity of the DX6's on-board memory means you will rarely, if ever, need to juggle models between transmitter memory and your SD card. The model memory menu is easier to navigate too. Only memory slots with model settings saved to them will appear. You won't have to scroll through empty slots or move models around if one is deleted.
Includes Full-Range AR610 Receiver
The AR610 combines the speed and precision of DSMX control with the signal security of an active amplified antenna. This antenna enables the receiver to “see around” reflective materials on a model and avoid polarization blind spots. Because it’s amplified, it can pick out its transmitter’s signal with remarkable clarity in noisy 2.4GHz environments. The AR610 also includes a data port for use with Spektrum telemetry modules and the Flight Log signal monitor.
Fly Smarter with Built-In Telemetry
The DX6 is equipped with a built-in telemetry feature that gives you real-time information on things like your model's battery voltage, signal quality, engine or motor temperature, airspeed, altitude and more.*
Using the voice alert system, you can program the DX6 to tell you when specific telemetry values reach or exceed limits you define. You can also have it call out a sequence of telemetry values on demand with the flip of a switch. If you want to review telemetry after a flight, the DX6 can be set up to record the data to its SD card.
Voor meer info klik hier
Mooi ding. Iemand al kunnen vinden vanaf wanneer hij leverbaar is?
Jammer dat de naam terug gaat naar 'DX6'
Er zijn al zo veel versies van een DX6 gamaakt..
Ik vind het wat jammer dat er WEER een nieuwe door spektrum wordt uitgebracht...
Ze brengen de ene achter de andere uit, maar hun software zit regelmatig met problemen..
Dit is al de 4versie als ik me niet vergis...
Van een DX18 zijn er ook al zo veel modellen...
DX18
DX18QQ
DX18t
Waarom zo veel soorten ? is 1 goed basis model 'DX18' niet genoeg ?
Ik vind het jammer..
Ach ja, toch een mooie zender..
Lijk op een DX6 (versie 1) maar nu met het scherm op de plaats van een DX6i (versie 2 & 3)
Ook wel leuk dat er nu eindelijk meer als 10modellen in kunnen ! die 10modellen zaten snel vol !
Mvg, Alex
Ben benieuwd wat hij gaat kosten in euro's. Ik kom met mijn DX6i niks te kort maar een kleine upgrade zou welkom zijn. Met name de betere gimbals is prettig.
Backlight is ook prettig, zonder dat is het schermpje bijna onleesbaar
Meer modelgeheugen is ook aardig. Ik kom niet echt te kort maar wat ruimer is beter.
199 euries met ar610 heb ik ergens op een webwinkel gezien. Weet wel niet meer als het Be Nl of De was. Maar dan hebben we een idee.
Dan zal hij in de loop van de komende maanden nog wel wat zakken in prijs en beschikbaar komen zonder RX.
Ziet er wel een mooi ding uot met handige functionaliteiten. Zouden de gimbals ook een upgrade hebben gehad?
Dat zou wel de moeite zijn. Weet jij toevallig ook als een dx7s dezelfde gimbals als een dx8 heeft?
Volgens mij wel. De oudere DX7 had andere gimbals meen ik. Maar 100% zeker weten doe ik dat laatste niet.
Ik las net dat deze zender een 3 standenschakelaar krijgt (handig met multirotors) en idle 1 en 2.
En het enige filmpje voor wie dit filmpje nog niet had gezien..
Heb vandaag de nieuwe SPEKTRUM DX 6 aangeschaft.
Een SD CARD zit er echter niet bij, welke SD CARD kan ik hiervoor het beste aanschaffen?
Iemand een idee ?
Ammo
Iemand een idee ?
Ammo
SD kaartjes hebben over het algemeen maar 3 eigenschappen waar ze op te beoordelen zijn, want betrouwbaar zijn de meeste merkkaartjes toch wel:
- snel/langzaam
- groot/klein
- het type kaartje, niet elk apparaat kan met elk kaartje overweg (SDHC, SDXC) maar dit heeft vaak met de capaciteit te maken.
In de handleiding van de DX6 wordt niet duidelijk welk type kaartje ondersteund wordt. (SDHC, SDXC, of gewoon ouderwets SD)
Er vanuit gaande dat hij gewoon SDHC ondersteunt (want dat is normaal):
Dit is een groot 16GB kaartje, dat héél vlot is. 30MB/s schrijven. Het is wel microSD, maar dat is wel handig, kun je hem ook ooit nog in andere apparaten gebruiken. De bovenste link op Tweakers, DataIO, verkoopt hem met adapter naar SD formaat, dus dan past hij sowieso in je DX6.
Voor de geïnteresseerden: De Turnigy 2s lipo voor de DX8 past ook perfect in de nieuwe DX6. Je dient de lipo alleen uit de zender te halen om hem te laden.
Tweede aanvulling: Het is mogelijk om je modellen uit de DX8 naar SD kaart te exporteren en deze daarna weer te importeren op je DX6. Hiervoor dienen de modellen wel geconverteerd te worden. Hiervoor kun je de volgende website gebruiken:
http://mutantdesign.co.uk/spm/
Neem voor een sd kaartje er een die class 10 is gecertificeerd. De class 4 werkte bij mij niet. Trouwens de Nederlandse handleiding komt eraan ;)
Groeten
Martin
