RCSoaring Digest (niet alleen zweven)
Discussie in 'Algemeen modelvliegen' gestart door ron van sommeren, 22 nov 2008.
  1. ron van sommeren
    31 aug 2002
    Druten / NL
    Front cover:
    A Ceres exiting a manoeuvre with Lions Head (SA) in the background.
    April issue is online
    www.rcsoaringdigest.com
    Highlights
    • Petre III - Peter Abell's 2-channel 2 meter RC sailplane.
      Reprinted from RC Soaring Digest July 1984.
    • Two Oceans Slope Soarers - Slope Aerobatic Event 2017
      Complete text coverage of the annual event.
    • Glue Caddy
      Steve Henderson describes the motivation behind his compact and efficient glue caddy and includes a matrix of materials and appropriate adhesives.
    • Gordy's Travels - Choreography of an F3RES Contest
      Whether you're an aspiring participant in this new Class or are a potential CD, you need to read this 3-page description for setting up an efficient event. Gordy Stahl covers team formation, flight timing methodologies, and standardizing hi-starts.
    • Minimizing Slop in Control Surfaces
      Dieter Mahlein describes the multitude of sources of both soft and hard slop in RC control systems, along with appropriate solutions.
    • Wing Tip Devices
      Various wing tip devices have been designed, experimentally examined, and incorporated in aircraft for over the last four decades. Chuck Anderson has been experimenting with wing tip devices for RC sailplanes over the same time frame. Here he presents his findings and explores a possible future for them with F3RES.
    • Tom's Tips - Magnets, magnets, magnets
      An attractive method for keeping frequently used tools close to hand.
    • Slope Soaring Candidate - Ilyushion IL-52.
      An obscure Soviet swept wing tailless bomber is the subject of this exposé.
    26.065
    Laatst bewerkt: 19 mrt 2017
    jve vindt dit leuk.
  2. ron van sommeren
    31 aug 2002
    Druten / NL
    Front cover:
    4 meter span SZD 59
    May issue is online, 15 articles
    Highlights
    • F3K Team Fundraiser Clinic and Competition.
      Held at Levin, New Zealand, April 1-2, 2017.
    • Australian International RC Glider Event.
      F5J, March 10 2017, and F3J, 11-12 March 2017.
    • Gordy's Travels - The Elegance of Contest Landings.
      Spot landings are often referred to as dork landings, or even crash landings. Here's another perspective.
    • Gordy's Travels - Hey, F3RES'rs! Rubber Milk is back!
      Protect your hi-start from deterioration with this product.
    • The Darmstadt D-17 and Chanute Sailplane.
      History of the D-17 airframe, from its original design, construction and flying in Germany, through its extensive history in the US, including its reconstruction as the Chanute and eventual destruction.
    • Performance Increase Possibilities of Gliders.
      A reprint of the DG Flugzeugbau library web page. Covers boundary layer suction, winglets, and flaps, plus a section on measuring L/D.
    26.285
    Laatst bewerkt: 27 apr 2017
  3. ron van sommeren
    31 aug 2002
    Druten / NL
    Front cover:
    Panavia Tornado GR1, PSS, 40" span, ~1,5kg
    June issue is online
    Highlights
    • The Sokol Glider.
      Uroš Šoštarič examines this postwar sailplane, circa 1947, and describes in detail the building of a six meter 1:2.53 scale model.
    • Egret and Kite - Two wood sailplanes.
      2 meter and 100" spans, designed by Tony Beck. An introduction to the overall design philosophy, a complete illustrated construction manual, plus links to downloadable full size plans (pdf).
    • How to lose or break perfectly good slope planes.
      Everything you need to know about avoiding catastrophic events on the slope.
    • Slope candidate - Bell X-2 Starbuster.
      Although it has a less than sparkling and some might say depressing history, slope soaring enthusiasts may find this aircraft to be well worth modelling. This would be especially true if an identically scaled B-50 could serve as mother ship.
    • Panelling a wing with plywood.
      Five videos describe the use of PVA and heat to mold a D-tube. Loads of fool-proof information in under a half hour. Videos downloadable from www.scalesoaring.co.uk.
    Bell X-2, crew, B-50 mothership and support equipment
    Laatst bewerkt: 19 mei 2017
