Kogel is door de kerk bestelling gedaan, nu wachten. Toch maar een 2350 3s 30C gepakt omdat die in stock was en voldoende moet zijn om te oefenen.
Het is geworden
Via ebay etc:
HP2812-1300KV Brushless Motor
K1BO Propeller pDD Park Flyer PROP 5pcs 8X4 GWS EP8040 P
10 Pairs 3.5mm Gold Bullet Connectors for RC Motor ESC Battery
1PCS USBasp USBISP 3.3V / 5V AVR Programmer USB ATMEGA8 New
Hitec HS-82MG Standard Metal Gear Micro Servo 32082S
Via HK:
Hartje:
9171000073 - Hobbyking KK2.0 Multi-rotor LCD Flight C..
3 x F-30A - Hobby King 30A ESC 3A UBEC
DL-Volt-Alarm - On Board Lipoly Low Voltage Alarm (2s~4s..
R2350-30-3 - Rhino 2350mAh 3S1P 30C Lipoly Pack
017000055 - 8045 SF Props 2pc Standard Rotation/2 pc..
Controler etc
JR-Combo - FrSky DJT 2.4Ghz Combo Pack for JR w/ Te..
9171000184 - Turnigy 9XR Transmitter Mode 2 (No Modul.. *This item usually ships within 3 days
9171000183 - Turnigy 9XR Safety Protected 11.1v (3s) ..This item is on backorder*
ACC6 - Turnigy Accucel-6 50W 6A Balancer/Charge..
Draadjes en dergelijk:
WHS-4MM-RED - Turnigy 4mm Heat Shrink Tube - RED (1mtr..
OR021-01006A - Servo Extention Lead 420mm (5pcs/bag)
R16A483-06 - Turnigy Pure-Silicone Wire 16AWG (1mtr) ..
XT60 - Nylon XT60 Connectors Male/Female (5 pai..
B16A483-06 - Turnigy Pure-Silicone Wire 16AWG (1mtr) ..
402000001 - Gyro / Flight Controller Mounting Pad (1..
WH-5MM-BLACK - Turnigy 5mm Heat Shrink Tube - BLACK (1m..
WHS-5MM-RED - Turnigy 5mm Heat Shrink Tube - RED
258000011 - 10CM Male to Male Servo Lead (JR) 26AWG ..
HS -160A - Cable Ties HS2.5x60mm 100pc (Natural Whi..
Clevis/11750 Quick link Steel Clevis w/ 2mm Threaded couplers (1Pair)
En nu een jaar wachten op het backorder item :/
Bankrekening of CC koppelen aan je PP account.
