Originally Posted by Croccy22
Just got my SJ400 this week (WiFi Version) and wanted to figure out how to control it myself without using their app.
If I get time I wanted to knock together a simple app for the Sony Smartwatch so I can start and stop recording.
Anyway I just thought I'd post my findings so far in case they are of help to someone.
First, you will need a device with Wireless (Obviosuly). Put your SJ4000 into WiFi mode and then connect to it from your PC.
Your PC will now get an IP Address from the camera and the camera itself will have an address of 192.168.1.254
If you browse to 192.168.1.254 in a web browser you can access the file system and copy the movies from the SD card onto your PC.
To view a live stream from the camera you will need VLC Player. Launch VLC player and from the Media menu select open Network stream. in the URL box type: rtsp://192.168.1.254/sjcam.mov and then click Play. You will now see the video being streamed into VLC.
Next up are the caemra controls. These are a little more tricky and I haven't investigated them all fully yet but here goes. To run any of these commands just enter them into a web browser:
To start the camera recording: http://192.168.1.254/?custom=1&cmd=2001&par=1
To stop the camera recording: http://192.168.1.254/?custom=1&cmd=2001&par=0
To list all the current settings on the camera: http://192.168.1.254/?custom=1&cmd=3014
The above will give you all the settings in an XML format. The simple ones will be 0 for off and 1 for on. Some settings like resolution can have multiple options like 1,2,3,4,5 for the different menu items. This would need to be documented fully by looking in the android app and listing all the values.
To change a setting just do: http://192.168.1.254/?custom=1&cmd={CommandHere}&par={OptionHere}
I think the options will be as follows but I have not tested all of them:
<Cmd>2002</Cmd> Resolution
<Cmd>2003</Cmd> Cyclic Record
<Cmd>2004</Cmd> WDR
<Cmd>2006</Cmd> Motion Detection
<Cmd>2007</Cmd> Audio
<Cmd>2008</Cmd> Date Stamp
<Cmd>2010</Cmd> Live View Size
<Cmd>1004</Cmd> Capture Mode
<Cmd>1002</Cmd> Image Size
<Cmd>1005</Cmd> Quality
<Cmd>1006</Cmd> Sharpness
<Cmd>1007</Cmd> White Balance
<Cmd>1008</Cmd> Color
<Cmd>1009</Cmd> ISO
<Cmd>2005</Cmd> Exposure
<Cmd>1011</Cmd> Anti Shake
<Cmd>3025</Cmd> Frequency
<Cmd>3026</Cmd> Rotate
<Cmd>3011</Cmd> Reset to Defaults
<Cmd>3010</Cmd> Format
<Cmd>3007</Cmd> Auto Power Off
<Cmd>3003</Cmd> WiFiName
<Cmd>3004</Cmd> Password
<Cmd>3008</Cmd> DV Language
So for example to turn on the Date Stamping you would do:
http://192.168.1.254/?custom=1&cmd=2008&par=1
These settings don't seem to take effect until you either start recording, or you turn the camera on/off. I assume there is a command to force the camera to re-read the settings but I have not found it yet.
There is also some commands to switch to photo mode/time lapse but I got bored before finding them
If anyone else want to try and find anymore information. Use a rooted Android device running Shark for root. Start this runing and then connect to the SJcam and perform whatever actions you want. Then look at the capture file on a PC using Wireshark and you will see all the http get commands that the application is issuing to the camera.
Hope this helps someone do something
Matt.
Als je geen 5.8 ghz transmitter kan kopen, koop dan een 2.4 Rx Tx.Ik heb een FC40 uitvoering van de Phantom ( die is gemaakt om met wifi te werken aangaande beeldoverdracht )
Die beeldzenders zitten op 5,8 .. en mijn zend/ontvanger zit daar op
( tenzij ik naar 900 of 1,2 ga )
Echt fpv vliegen op wifi gaat inderdaad niet, de verbinding is gewoon te traag en bevriest af en toe. ( geprobeerd, lukt niet)
Gaat mij er om om te zien hoe de camera staat.
FPV setje zal ook nog komen, ( op eerder genoemde 1,2 of 900 ) alleen , stapje voor stapje![]()
Als het goed is de SJ4000 een ( op formaat ) copy van de gopro
( het is een kloon )
Volgens mij is hij alleen iets lichter.
Er mij geadviseerd 2 camera's te gebruiken, 1 voor mooie plaatjes ( de sj4000 )
1 voor FPV ( met de zender eraan geknoopt op juiste band )
Ik heb specifiek voor de SJ4000 ( wifi ) gekozen voor 3 redenen..
1: Prijsheb geen gopro geld
2: de timelaps functie voor andere doeleinde
3: Wifi optie ( aangezien ik een FC40 Phantom heb en wifi "mag" gebruiken )
En als *bonus* blijkbaar kan je om de paar seconden een foto laten maken in hoge
resolutie, aangezien die optie op m'n FC40 camera totaal waardeloos is.
Ik ben helemaal nieuw hier op dit forum en ga straks kijken voor een Dji Phantom 1 met Tarot Gimbal. Nu is de Tarot bedoeld voor een Gopro maar lees ik hier nu net dat de SJ4000 ook in de Tarot Gimball past? En dat je deze ook goed kan gebruiken voor FPV?
Zou mooi zijn want een Gopro vind ik wat duur...
is wel grappig dat geen een van de videos wat ik van de sj4000 zie niet in de buurt komt van de sample in de video boven.een sj4000 is 3.7mm dikker. voor de rest niks
gelijk.
een lcdpack voor de gopro is veel dikker dan dat
SJ4000 VS GoPro Hero 3 BE (Full HD): http://youtu.be/MGL_kYuzykQ
