That is the downside of free software. It might be possible in Fusion, however it could be a feature you have to pay forThank you unusual! I add dimensions on the plans and fortunately they are 100% accurate!
To be honest I prefer cutting the templates by myself.
Unfortunately it is not possible to flatten a surface in Fusion 360. It would be very useful for skinning.
This is very Interesting Jan. I thought that having the flattened surfaces would be a huge benefit to speed up the process and improve accuracy but I was wrong. Good to know, thank you.Having the ribs printed 1:1 is already a huge plus.
Flatten the surfaces for making the plating contours is in my opinion not a huge added benefit. I never used it, although I know the feature. By hand building, you will always find some imperfections. Using paper and cardboard for making templates of the plating works maybe even better in that case.
Its looking good.Update #5.
I changed somewhat the design of the hull and I had to re-cut the ribs and re-construct the construction board. This is the progress I ve made so far.Bekijk bijlage 473024
Bekijk bijlage 473028
Bekijk bijlage 473029
