Ik heb vandaag deze lader gekocht en even getest en tot zover boven verwachting. Heb even mijn twee 3s 8400mah lipo's (half vol) er aangehangen en kon ze met bijna 17 ampère laden tegelijk. Als ik de lader wat langer heb zal ik een update maken. Two outputs, each with 200 Watt power and up to 20 A charge current, in a single case. The Power charger which can recharge your LiPo batteries on the move and at home - and very quickly. Both charge circuits work entirely separately of each other, and can also be adjusted individually. The charge data for all outputs are displayed in clear form on separate backlit graphic screens. The menu language can be selected from German, English and French. The high-performance integral equalizer measures the cells whilst drawing zero current, and balances them at a powerful 300 mA, which is sufficient even for batteries with a capacity of 5 Ah and more. The device features mini-USB sockets which the user can employ to update the software at any time. In future the charge data will also be present at these sockets, so that the information can be read out and processed using the new Logview software. A 5 V / 1 A USB charge socket for smart-phones, digital cameras and sat-nav devices, etc., is also present. Simple, reliable operation and automatic saving of the essential battery data using the robbe BID system (Battery IDentification system). The special advantages of the BID system: Simply plug the BID key into the charger, and start the charge process. No need for tiresome charge parameter adjustment in the menu system Maximum protection from incorrect operation Storage of essential battery data on the BID chip or key Of course, the Power Peak Twin charger can also charge batteries not fitted with the BID system Two BID chips are included with the charger. Set contents 1 Power Peak D7 12/230V 1 Universal charge lead 2 Croc clips 2 BID-Chips 1 Manual Functions: Input: 10.5…18 V DC (user-variable low voltage alarm, 11…12 V) or 100…240 V AC (plug-in lead with On / Off switch) 2 x 0.1…20 A charge current (max. 200 W per output - 12 V or 230 V) 2 x 0.1…10 A discharge current (max. 40 W per output) USB charge socket, 5 V / 1 A for smart-phones and digital cameras Internal resistance measurement Internal device temperature display 2 x 20 internal battery data memories Charge / discharge (cycle) – mode 1 - 10 x with capacity display per cycle Mini-USB socket for firmware upgrades and future data output Menu system can be set to German, English, French or Italian. Over-temperature guard Current overload protection Short-circuit protection NC / NiMH batteries 2 x 1…18 NC / NiMH cells Charge process: automatic, normal, linear and reflex methods User-variable trickle charge current (50…300 mA, off) Variable peak sensitivity (3…15 mV / cell) Variable pre-peak suppression (1…5 min., off) Lithium batteries, LiIo (3.6 V), LiPo (3.7 V) or LiFe (3.3 V) 2 x 1…7 Lithium cells - charge and discharge, cycle Powerful balancer with 300 mA and zero-current measurement Selectable charge power, up to 5C (20 A) User-variable maximum cell voltage Safety timer cut-off (20...720 min., off) Maximum capacity cut-off (0.1…60 Ah) Storage mode (60%) Fast-charge mode without balancing function Separate balancing program 0.1 Volt boost function for Lithium batteries. Increasing the cut-off voltage by 0.1 Volt provides approximately 10% more battery capacity. Lead-acid batteries 2 x 2…24 V lead-acid batteries - charge and discharge
Ben nu ook op zoek naar een nieuwe lader en heb hier ook wel interesse in. Ik gebruik nu een T2M Swallow lader 50 watt maar dat duurt mij te lang voordat mijn accu (6s 9000 maH) volledig is opgeladen. Ruim 4 uur is mijn lader bezig. Is er iemand die mij kan vertellen wat ik voor laadtijd kan verwachten met deze Robbe Powerpeak D7 lader? Als ik mijn accu laad met 1c.
Als een lege LiPo laad met 1C zal je theoretisch 1 uur laadtijd hebben. De laadtijd hangt ook af van de onbalans die er tussen de cellen is. Hoe kleiner de onbalans des te korter is de balancer bezig om dat weer recht te krijgen dus zal het hele laadproces ook korter duren. Hierdoor, en omdat laden ook wat energie kost, zal je in de praktijk aan ongeveer 75 tot 90 minuten moeten denken. Er is echter één probleempje met deze lader. Je kan die 6S accu niet met 1C laden! Deze lader kan een laadvermogen leveren van maximaal 200W. Voor een 6S LiPo betekend dit dat hij niet meer dan 8A zal kunnen leveren. De laadtijd zal dan al snel tussen de 90 en 140 minuten bedragen. Om een 6S / 9000mAh LiPo met 1C te kunnen laden heb je minimaal een 250W lader nodig.
Hij heeft ook een snel laad functie en dan laad hij met de max ampère tot het eind. Waardoor hij sneller klaar is uiteraard. Wat ik begreep uit de beschrijving belanst hij dan ook nog maar iets minder nauwkeurig en je accu's gaan net iets minder vol als bij het balans laden. Maar heb dit nog niet uitgeprobeerd.
Dat is bij LiPo's "levensgevaarlijk". Wanneer de maximale spanning van de cel ie bereikt moet je absoluut niet doorgaan met laden met de maximale stroom. Daarvoor moet je namelijk die spanning verhogen en dat kan bij LiPo's dus echt gevaarlijk worden! Maar eerlijk gezegd geloof ik niet dat er laders zijn die dat doen! De fabrikanten van laders weten heel goed dat het gevaarlijk is en ze willen niet aansprakelijk gesteld worden als het fout gaat. Die zogenaamde "snel laad functie" betekend vrijwel altijd dat de lader al aangeeft dat de accu vol is wanneer de laadstroom begint te zakken. Dan is de accu meestal ergens tussen de 80% en 90% vol. Veel mensen vinden het niet zinvol om nog een kwartier tot een half uur door te gaan met laden voor die laatste 10% tot 20%. Wanneer de lader dus stopt is de accu stiekem nog niet echt 100%vol.
fast charge (Li-xx batteries only) The process is switched off if all the cell voltages are adequately balanced, and the defined "TVC voltage" (in the "Memory name" menu) is rea- ched. The charge current is not reduced. This is a charge process which charges the battery very rapidly, with a good compromise between cell balance, charged-in capacity and charge time.
Hij gaat natuurlijk ook niet over de 4.2 volt per cell. De tvc staat standaard op 4.2 en kan ingesteld worden van 4.18 tot 4.25 volt. Dus als een van de cellen de ingestelde voltage berijkt stopt hij met laden van de cell. Als ik het goed begrijp.
Lees eerst eens goed door hoe een LiPo geladen wordt, er is voldoende over geschreven. De absoluut maximale spanning die een LiPo cel mag zijn is 4,235V. Uit veiligheidsoverwegingen staan de meeste laders op 4,2V ingesteld. Die laatste 0,035V is minder dan 0,5% lading dus dat merkt niemand. Op het moment dat de spanning per cel heel dicht bij die 4,2V komt wordt het verschil tussen de laadspanning en de accu spanning steeds kleiner. Hoe kleiner het spanningsverschil wordt des te lager de stroom zal worden. Daarom gaat de stroom niet direct naar 0 maar zakt die langzaam. Hoe langzaam, of snel, hangt af van de accu, dat doet de lader dus niet! Als je de stroom toch hoog wilt houden kan je niet anders dan de spanning verhogen, dat is echt de enige manier. Daarmee is de kans op overspanning groot en dat kan echt gevaarlijk worden. Geen enkele verstandige lader fabrikant zal dat risico nemen. Een schadeclaim van een klant kan heel veel geld gaan kosten en je bent direct je goede naam kwijt. De computer in de lader meet constant wat de cel spanningen zijn. Wanneer die 4,2V is zal hij het laden stoppen en aangeven dat de accu "vol" is. Dat de accu in werkelijk nog niet echt 100% vol is wordt er niet bij gezegd maar dat is wel zo. De vraag is wel of je dat zal merken. Als je een goede accu hebt zal de stroom heel lang hoog blijven dus zal je accu goed vol komen, 90% is heel goed haalbaar. Een oudere, of slechtere, accu zal eerder de stroom doen zakken en zal dus minder vol zijn als de spanning in de buurt van de 4,2V komt en de stroom begint te zakken. Als je accu ouder en slechter wordt zal je het wel kunnen gaan merken.
@Queryn, ik heb deze Power Peak D7 nu een drietal maanden. Fijne lader, die in een compact formaat mooie prestaties levert. Ik heb echter een tweetal vragen waar jij me misschien mee verder kunt helpen: 1. Storage Mode. Wanneer ik een lipo met de standaard storage mode van de D7 ontlaad, dan eindigt hij het (ont)laadproces bij 30% (wanneer ik dit daarna controleer met een lipo-checker). Wat ik begrijp van mijn mede clubleden en van diverse forums, hoort storage rond de 50% te zitten. Doet jouw D7 dit ook? Ik kan geen optie vinden om dit aan te passen in de settings. 2. Firmware update. Heb jij al een firmware update kunnen vinden voor de D7? Op de Robbe website en op andere RC forums is niets te vinden. De lader is zelfs niet meer te krijgen... hoop niet dat dit een slecht teken aan de wand is, omdat er bijvoorbeeld iets mee aan de hand is. Misschien dat jij deze firmware update ergens anders hebt kunnen uithalen?
Het probleem is niet dat de accu nog voor 30% vol is of dat het 50% moet zijn. Hoe "vol" de accu is volgens die LiPo checker is totaal niet belangrijk. Het is al meerdere keren geschreven dat de spanning van de accu geen goede indicatie is voor de ladingstoestand. Wanneer de accuspanning na het laden of ontladen tot de bewaarspanning (storage) ergens tussen de 3,6V en 3,9V per cel is zal dat prima in orde zijn. Veel laders zijn ingesteld op 3,8V per cel, wat een goede waarde is. Die spanning is dus belangrijk en niet of de accu dan nog voor 50% of 30% vol is.
Zo als Ernst al aangaf is de storage ingesteld op 3.8v per cel en dat is perfect om ze te bewaren. Let alleen wel even op als je ze echt lang niet gebruikt ze even te kontroleren of de spanning nog goed is. Omdat de lader nog erg nieuw is is er nog geen update je kan het op de site vinden.
Ik heb ook een vraag, ik heb deze lader vorig jaar aan geschaft, maar nu is mijn vraag, kan ik de memory name veranderen in bv de name vd lipo ??
Je kunt per modelgeheugen alleen het type accu opgeven. Als je de bid-chips gebruikt hoef je zelf niets te onthouden, als je deze niet gebruikt kun je als geheugensteuntje het nummer van het modelgeheugen op de accu's plakken.
Een vraagje over deze lader. Ik heb een fat shark fpv gekocht, met een 2 cell lipo, maar nu komt het, het balance stekkertje wat eraan zit moet NIET in de balance poort vd lader, daar deze lipo zelf balanceert. Maar als ik die weglaat geeft de lader aan balance error. Dus dat moet ik zien te omzeilen. Nu heb ik wat rond gespit, maar kan helaas niets vinden, dus mijn vraag luid : Kan ik met deze lader ook lipo's laden ZONDER balancing ??
