40mm, 18slot statormotor: draaidelen kunnen besteld worden
ron van sommeren
Forum veteraan
Ralph Okon (a.k.a. http://www.powerditto.de ) is putting together a group order for 40mm. diameter, 18pole statorlaminations. A minimum order of 5000 laminations is needed to start a production run. Minimum order per person is 50. One 0.20mm lamination (NO20 iron quality) will cost 0.5€. Flux ring and frontplates will probably also be available by then. Keep in mind, this is not a business for Ralph, he's in the business of curing people :-)
More info on ordering;
http://www.rcgroups.com/forums/showthread.php?t=392627
I'm posting this in several lists/forums, think it's best if we all discussed/asked in the thread above.
Sometimes one of the 'poets' is a wee bit lazy ;) Heeft ook geen zin om in het Nederlands te vertalen aangezien het een verwijzing is naar Engelse tekst.
Rahlp Okon a.ka. powerditto zei:
I think, you should better calculate with ca. 4 per mm, because of the needed insulation between the plates. in summery 40 up to 45 per cm I think.
we are looking now for curved magnets for the project.
it seems, if there are enough users who join the project,
ist could give a complete set (can, bearings, etc.) for the motor.
lenght then 5, 10 and 15mm in first attempt.
and the baby has a name now:
its our "CROCODILE"
-has many teeth too, more then the others :D
-seems to be leazy, but is a very powerfull animal.
- there are big elektrical lokomotives(?) for railway, also named so:
http://www.ozdoba.net/rhb/croco_d.html
if you are interested in more details, please have a look at
www.powerditto.de/crocodile-project.html
we have orders for 2000 statorplates now and we need minimum 5000 to get this very good price.....
viele grüsse,
ralph
www.powerditto.de
Er zullen ook lagers, assen, magneten en gedraaide onderdelen beschikbaar komen. Meer info:
Engels:
http://www.powerditto.de/crocodile-projectengl.html
Duits:
www.rclineforum.de/forum/thread.php?threadid=88112&sid=&threadview=0&hilight=&hilightuser=&page=4
http://www.powerditto.de/crocodile-project.html
(Weet iemand een beter woord voor 'draaidelen'? Letterlijke vertaling van het Duitse 'Drehteile', het ziet er niet uit maar ik weet zo gauw geen betere term voor onderdelen die op een draaibank gemaakt worden. Idem 'gedraaide delen' als letterlijke vertaling van 'turned parts'.)
The turned parts and laminations for the 40mm 18statorpole Crocodile diy outrunner motor can be ordered from http://www.neodyme-magneten.de/ (Sandra & Holger Beckfeld).
Zoals op de foto's is te zien, bestaat de rotor uit één deel, niet samengesteld uit een flux ring en aandrijfplaat, net zoals de motoren van www.shp-motoren.de (Frank Schwaab)
David Theunissen's Crocodile pages, lots of info:
http://www.flyelectric.ukgateway.net/
-> diy brushless motors
-> Crocodile motors
Ralp Okon's Crocodile pages (English & German)
www.powerditto.de
-> English
-> Crocodile project
Pictures
http://www.rclineforum.de/forum/thread.php?sid=&postid=1012697#post1012697
Wolfgang Mrotzek's Crocodile pages:
http://goldeneye.ethz.ch/motoren/electric/index_EN
-> Motore
-> electric engines
-> Krokodil
From www.neodyme-magneten.de :
"PLEASE CONSIDER THAT THESE ARTICLES HAVE APPROX. 6-8 WEEKS DELIVERY TIME ! "
Onderstaand de delen van de huidige batch die nu uitgeleverd wordt. Frank Schwaab van www.shp-motoren.de heeft gezorgd voor een goed kontakt met een metaalbewerkingfirma, waarschijnlijk dezelfde firma die ook voor hem draai- en frees-werk doet.
