Hallo Dirk,
Misschien ben je hier iets mee. Ik heb het zelf wel nog niet geprobeerd.
origineel draadje:
DSX9 Fault - Page 2 - RcHeliaddict
Tekst die daar staat:
Accessing the X9303 and XP9303 Service Menu:
Pull Throttle Hold switch into the forward position.
Pull AILE D/R switch up.
Power the set on while keeping ENT button on front panel pressed.
Rotate roller activator until Trim Step is highlighted.
Press roller activator on Trim Step, rotate to AILE.
Switch AILE D/R down, press roller activator, switch AILE D/R up, press roller activator.
Repeat Step 6 four more times and on the 5th (total) time access should be granted to the Service Menu.
Here is a list of things you can do - should be in order as you scroll through each item. This is not a complete list, and there are likely lots of other things that can be done.
From here, SW test allows you to test each switch and microswitch.
The next menu item is Hard. Con. By rotating the selector bar it becomes obvious what can be changed by soft selection. Where the highlighter does not move it indicates that this is a hard connection on the PCB, but in conjunction with the table this can be modified accordingly.
Next item is Stick Neutral. Center all sticks and side trimmers, press CLR followed by STO. This then stores all the centers for the sticks.
Next is Stick Ga. Moving all sticks and side trimmers to max & min positions finalizes the stick calibration.
Moving the selector across to the right allows for setting front panel voltage, and at what voltage the alarm will activate for low battery.
There are various ways to exit, and each one has a different effect. Total reset of system and loss of models stored, reset of the config data only. For straight calibration purposes, rotate back to EXIT and press the button next to : Reset start (No Initialized)
