Align 25 Amp Electronic Brushless Speed Controller
  • Topicstarter Topicstarter ejpsx
E
ejpsx
kan iemand mij even in het kort uitleggen hou ik deze kan programmeren??
Ben namelijk een beetje verwend met de castlle phoenix met usb progger..
heb hier een setje bij de t-rex gekregen met motor en esc,alleen vraag ik mij af of deze wel correct staat..
grtzzz erik jan
Setting up the Align ESC is not overly complicated but quite confusing if you don't know what all the beeps are about.
The following is a description in words of the setup procedure, bear with me as it is quite complex to explain.
Firstly your tx must be setup such that your throttle curve is the default linear curve. ie. 0 25 50 75 100 for a radio with a five point curve. The reason for this is that the ESC uses the stick position to sense what settings you want during the programming phase.
Next step is to put your stick at full throttle and plug in the battery (yes, I was also worried).
The ESC will emit a scale (crecendo) of notes in quick succession indicating setup mode being entered.
Put the stick at low throttle and the setup sequence begins.
The ESC will now emit a single beep, repeating slowly, this indicates option 1 is being set. Put the stick in the appropriate place for the setting you want. Option 1 is the break setting, so should be turned off in a heli, so the stick should be at low throttle. The ESC will wait a preset period of time beeping once slowly and then take the option as wherever the stick currently is placed. If you are following these instructions then you won't have moved the stick from the low throttle position at the start of the setup sequence.
The ESC now emits a scale of notes in quick succession to indicate the setting has been taken and will now beep twice, slowly and repeating. You are now setting option 2, hence the two beeps slowly repeating. You are now setting the timing for the motor. Place the stick in the appropriate place for your motor. Option 1 is low timing, option 2 is mid timing and option 3 is high timing. For an Align motor mid or low timing can be used, so middle or low throttle for the stick.
After a preset period the ESC will emit a scale of notes in quick succession, indicating the option has been set.
Following this the ESC will emit three beeps, repeating slowly, you are now setting option 3 for battery protection.
Again place the stick high, middle or low. I set my battery protection to high (70%) which is the low throttle stick position. This gives you just under 9v as the point your ESC will enter battery protection mode.
After a preset period you get the scale of notes in quick succession and then the ESC plays back your settings using beep codes for option 1, 2 and 3. Listen carefully to verify they are correct.
If they are then unplug the battery, plug it back in and go fly. If they aren't correct unplug the battery, place your stick at full throttle and plug the battery back in again to re-enter setup mode.
I hope this makes sense, it's very hard to explain, I may make a video of it with commentary at a later date if I receive feedback that this is too hard to follow. Let me know on the TrexTuning forums.
450 DHAlign 400 LAlign 400 SAON V2815-3000AON V2815-3500Chilli Pepper400 DHE-Flite Park 400FeigaoHacker B20LHimax HA2025LehnerMedusa Power Analyser PlusMedusa Products MR-028-040-3400Mega 16/15/3Mega 16/15/3Mega 400 LNEU1105SHP SS23Warp 4Medusa MR028-032-2800
Inderdaad,dit is net wat ik ff zocht!
Vriendelijk bedankt vanaf deze kant,kan ik even de regelaar nalopen,heb zo`n idee dat hij niet goed staat..
Nogmaals vriendelijk dank!
