New: Update V3.0.8
Hi,
firmware V3.0.8 is now available in the download section.
Changes from V3.0.0:
Unfortunately since V3.0.0 receivers with SRXL protocol could not be used because power output to swash and tail servos has been seriously disturbed. This could range from slight twitching to total dropouts for several hundred milliseconds. As this was depending on the chosen servo frequency and the applied servos, we didn't notice.
Improved locking in on the elevator axis when using large / heavy helicopters.
Uniform rotation rates on aileron and elevator when same amount of stick input is applied.
Adapted values in parameter menu points G and H. The values are now lower in the beginning and rise progressively.
Improved sensor signal conditioning.
Note: This update uses the same database version (V6.1) as V3.0.0. I.e. when V3.0.0 is already used on the Microbeast, the basic settings will not be changed when updating to V3.0.8. However, please note that the values in parameter menu points G and H slightly changed! We recommend for the first flight to switch these parameters back to the default values (Status LED purple) and then again adjust them as desired.
Hi,
