benedini mini sound module
Iemand hier ervaring mee?
Prijs en de formaat staat me wel aan eigenlijk.
Soundmodule TBS Mini
This soundunit is developed specially for electric powered airplanes or other models having a lot of functions.
It is a further devolpment of the proven TBS Micro.
In comparison to other competitors, you can use any sound available in the download section for FREE at the TBS Mini or Micro.
Please find a short introduction about adding sound to electric airplanesHERE
Manual TBS Mini (PDF)
Features:
Fully customer programmabel, free of charge sofware at DownloadsLarge FREE OF CHARGE sound libraries of original recordings (f.e. Corsair, ME109, Spitfire, Cessna, dif. Trucks)Soundquality 22KHz16Mbit Soundmemory, enough for 93s of soundrecordingsInternal 1,2W amplifier at 8 Ohm speakersExternal high power amplifiers available
(f.e.. 2x40W at 2Ohm and 12V OR 50W at 8 Ohm and 50V supply)Up to 6 electronic switching outputs
- activated by sound (f.e. Muzzle flashing with MG sound) or independant operation
- permanent, momentary or flashing mode adjustable
- direction flashingExternel smoke generator for exhaust simulation (see below). Not recommended for aircrafts !Twodigital inputs for triggering sounds by a external signal
(f.e. Screaming tires at touch down, triggered by a switch)Twoservo signal outputs, f.e. for retractable landing gearsAll connections done by plugs, no solderwork necessaryReceiver signals are used for speedinformation, this allowsbrushless or DC Motor usageAll connections horizontally -> full isolation and protection by shrinked plastic tube possibleFully assembeled in SMD technology (no heavy, vibration sensitive components)All wires includedVery little dimensions and weightUSB or RS232 programing interface by external adaptor (optional)Can be fully configured by free of charge PC software:
- you can make your own soundcreation or using the originalBenedini sounds
-Firmware update, your unit can be updated by your own with the latest softwarePlays two sounds simultaneously (engine plus a special sound) from TBS Flash Ver. 1.0.1.0 on
Technical Datas:
Supplyrange: 3,5 – 12V (from receiver)
Internal amplifier: 1,2W at 8 Ohm and 5V supply
Switching outputs: Minus switching, max. 12V/0,5A each
Dimensions: only 55x25x10mm !
Weight: only 6g !
Prices TBS Mini:
Fully programed with standard configuration, ready to run : 99 Euro
http://www.benedini.de/html/sound___smoke.html
hoor het graag
zo te lezen is de mini versie neit instelbaar / programmeerbaar?
dat zou jammer zijn, anders had het een concurrent kunnen worden voor de beier.
volgens mij wel Alwin
Features:
Fully customer programmabel en ben al diverse filmpjes tegen gekomen dat het in trucks ligt.
ga zeker me eigen nog even in verdiepen.
mocht het zo zijn zeker een mooie concurrent voor beier
