Bix 3 van HK ervaringen
Hoi leden,
Zoals jullie misschien al gelezen hebben vernomen hebben is sinds nog niet zo heel erg lang de 'Bix 3' bij Hobbyking beschikbaar. Aangezien de Bixler I en de Bixler II vrij succesvol waren lijkt het erop dat deze het ook aardig gaat maken.
Voor zover ik weet is hij alleen nog in de 'global' store beschikbaar, ik hoop dat hij snel beschikbaar wordt in de EU store.
Zijn er hier al mensen die hem hebben besteld, of beter nog, er al ervaring mee hebben? Ik ben ieder geval zwaar aan het overwegen om hem te bestellen :D
Beschrijving:
Now in its third generation, HobbyKing™ brings you the Bix3, the ultimate training airplane and FPV platform. The Bix3 is the biggest, most versatile, and complete version of its family lineage. Coming with removable landing gear, plywood FPV tray, plastic belly skid, and optional flaps, you can customize your Bix3 exactly how you want it. Looking for the perfect trainer? Or an in-expensive FPV platform? The HobbyKing® Bix3 is it.
The Bix3 has all the right ingredients; made from super tough EPO foam, everything is pre-installed so minimal assembly time is required. In fact, by the time you have charged a battery, it should be ready to fly! The combination of size, low wing loading and a sleek fuselage make for an excellent model with capable, yet forgiving flight characteristics. The snap together two-piece wing makes the Bix3 a practical model that is easy to transport to your favorite flying field and can be ready to fly in just minutes.
Other practical features of the Bix3 include the large battery area that can accept a wide variety of battery sizes or house FPV equipment, plus the Bix3 also comes with optional flaps which can help cope with the extra weight. Simply install your own 9g flap servos, glue in the included hinges and you're ready. Even the control horns , pushrods, and Y-harness for the flaps are included in the box. We've upped the ante on the Bix3 by adding removable tail dragger landing gear including a steerable tail wheel. If you do not want to use the landing gear we have included a clear plastic belly skid to better protect the foam fuselage. Additionally, the belly of the Bix3 features two built in threaded inserts for optional accessories or anything you might dream up to mount to the bottom. Adding to the ruggedness of the Bix3 is a carbon tube that runs down the length of the aft fuselage, all the way to the tail wheel, so snapping a fuselage in half is a thing of the past.
For the FPV junkie, we have included a option plywood fpv mounting tray that replaces the stock sport canopy. This tray is perfect for setting up a camera with pan and tilt. For a fixed position camera, the nose is removable, able to accept small 1 inch square form factor cameras.
The larger wing, flaps & much larger canopy area mean that the Bix3 is a much more versatile airplane in terms of FPV use and for pilots who are simply flying for fun. However you decide to fly the Bix3, you can be assured that it is just as fun and easy to fly as ever!
Features:
• Easy and fun to fly
• Plug and Fly - Just add your battery and radio equipment
• Larger canopy area to accomodate FPV equipment and/or larger flight battery
• Pre-installed servos & brushless motor
• Large wing for better slow flight and weight capacity
• Easy slip on landing gear with steerable tail wheel
• Includes removable plywood FPV canopy mount platform
• Pre-Installed optional flaps, just requires two servos
• 2-piece wings for easy transportation
• Carbon tube runs length of fuselage for superior strength
• Removable nose piece to accept FPV camera.
Specs:
Wingspan: 1550mm
Length: 948mm
ESC: 20A
Flying Weight: 890g
Motor: 2620-1400kv Brushless Outrunner
Prop: 7x5
Servo: 4 x 9g
Required:
4~5 Channel Transmitter and Reciever
1800mAh~2200mAh 3S Lipoly Battery
2 x 9g Servo For Flaps (Optional)
Video:
Wat vinden jullie ervan?
Ik heb zelf de Bixler 2 sinds kort dus echt oordelen kan ik er niet over maar,
-persoonlijk vind ik de "looks" van de bixler 2 beter dan de 3. dat hoekige valt tegen..
-de grotere opening voor de elektronica is een goede verbetering, zo kan je tenminste goed bij die zeeën van ruimte.
-het nieuwe systeem hoe de vleugels worden vast gezet is ook een stuk handiger dan die schroefjes.
-afneembaar kapje in de neus op een mooi afgewerkt FPV cameraatje te monteren is erg leuk en handig bedacht.
mijn mening; goed vliegtuig, verbetering van de bixler 2 maar het uiterlijk is net niet wat het eigenlijk zou moeten zijn. als ik nog geen bixler 2 had, had ik waarschijnlijk de 3 gekocht i.p.v. de 2.
succes met je keuze!
Gr. Sam
Gr. Sam
Hoi Sam,
Ik heb een tijdje terug de Bixler II gehad maar omdat ik veel met tape werkte in plaats van lijm (makkelijk voor onderhoud dacht ik :) ) en een motor upgrade had gedaan scheurde het hele zooitje midden in de lucht uit elkaar. Toestel lag in stukjes op het grasveld. Hij was dusdanig kapot dat ik niet zo'n zin meer had om hem te gaan repareren.
Persoonlijk vind ik de hele Bixler/Bix serie niet mooi, maar daarentegen vliegen ze wel makkelijk en fijn :). Ik ga er nog even hard over nadenken. Ik heb hier ook nog een Mustang P51 van Parkzone liggen die ik in elkaar aan het zetten ben.
Landingsgestel
Ze hebben gemeend er een landingsgestel op te moeten zetten, waarschijnlijk omdat er vraag naar is :rolleyes: Toch is het sterke van een Bixler-achtige nou juist dat er geen landingsgestel nodig is. Je kunt makkelijker landen op hoog gras en ongelijke grond, terwijl je voor de vrij kleine wielen van dit type juist een goed vlak terrein nodig hebt.
Het landingsgestel zit erbij, maar het hoeft er niet op. Je heb dus zelf de keuze.
Lokaal vliegen hier vrij veel piloten met zelf gefabriceerd landing-gestel onder hun Bixler.. Dus vraag is er zeker naar..
Voor de Bixler 2 is ook een onderstel beschikbaar. Natuurlijk land de Bixler prima op ongelijke ondergronden, maar juist als je op een stuk asfalt wilt landen ben je met een onderstel erg blij. Op gras is het denk ik niet heel zinvol.
De Bix 3 is sinds kort verkrijgbaar in de EU store van Hobbyking. Momenteel is hij wel uitverkocht. Iemand van Hobbyking wist op RC Groups te melden dat hij binnenkort weer op voorraad is.
They are headed to the US warehouses right now. They'll be live in UK in the next few days, and in EU shortly too.
Zodra hij beschikbaar is ga ik hem bestellen denk ik. Heeft hier iemand inmiddels al ervaring met dit toestel?
Als je hem dan wil bestellen moet je er wel bij zijn op de dag dat hij weer binnen komt.
De vorige dag was hij ook in een halve dag weer uitverkocht..
Voor eventueel geïnteresseerden: ik ben bezig met een video-serietje, met uiteindelijk ook een review van et vliegtuig :)
Bij deze alvast de unboxing:
Leuk om te zien! Ik heb inmiddels de Easystar II met een motor upgrade aangeschaft om weer een beetje in het vliegen te komen :)
Dat is zo'n beetje een zelfde soort vliegtuig uiteraard.. Zal prima vliegen! Succes uiteraard :)
Klopt inderdaad, ik had niet genoeg geduld om te wachten op de Bix 3, ondanks dat de Bix 3 iets meer compleet is. De prijzen zijn volgens mij uiteindelijk bijna hetzelfde dus daar hoef ik het ook niet voor te doen.
Als het toestel weer op voorraad is ga ik het zeker nog even overwegen! Ik ben benieuwd wat je ervan gaat vinden.
Is de EasyStar niet enigszins duurder? Ik weet het eigelijk niet helemaal..
Maar! In het kader van 'wat ik ervan ga vinden', bij deze mijn after-build thoughts :)
Was dat informatief zo??
Leuke en een interessante video! Leuk dat je er tijd in gestoken hebt, ben ook wel benieuwd hoe je hem vindt vliegen. Wat betreft de prijs zal het niet heel veel schelen denk ik. Ik heb de Easystar II (Kit) voor 70 euro inclusief verzendkosten besteld.
Ik moest alleen nog de elektronica erbij aanschaffen. De Bix 3 is tegenwoordig wel completer en uitgerust met 'nieuwe' technieken (vleugels en landingsgestel).
Dank u :)
Mijn referentie is eigelijk de Graupner Rooky, die ik jaaaren geleden als 1ste gekochte toestel had :) Dat is uiteraard ook een toestel in deze catagorie..
Ik GOK dat de Rooky wat sneller was, maar we gaan het meemaken.. Hopelijk kan ik 1-dezer-dagen de Bix3 een paar keer de lucht in sturen :)
Dank u :)
En al gevlogen met de BIX3 :cool:
Jan
Helaas nog niet :( Ik kijk uit naar fatsoenlijk weer.. Op zich vind ik het niet erg om met (veel) wind te vliegen, maar dan zegt het gedrag weer niet zoveel over het vliegtuig.. Niet wat voor een goede maiden zo..
Et voila! Bij deze mijn final review van de Bix3, met een stukje vlieg-video ook :)
Bij deze een ingekorte versie van dezelfde vlucht met live commentaar:
Kortom: prettig beginners toestel dat zelfs in thermiek z'n mannetje zal staan als zwever (motor uit)!
