Heb beetje interesse gekregen in crawlers en was beetje aan het surfen op het internet en vind deze pracht crawler :
The Boyer Truggy is extremely versatile so you can set it up any way you like. Different bodies, different size/length shocks, adjustable wheelbase, adjustable frame mounted servo, adjustable rock sliders and adjustable front brush guard. Plus it has pre-drilled holes for mounting the winch on the bumper. The rock sliders are threaded so they can slide in and out to adjust to the width of the body. They are also offset so when you switch them side to side then that allows you to run the regular cab bodies like the Hilux. When you switch them side to side the rock sliders will sit further back on the chassis. [FONT=Arial, Helvetica, sans-serif]Once you place your order, please allow 4-8 business days to process your order. [/FONT]
Chassis main features:
Boyer Truggy is the first that comes equipped with a functional winch:
Installed with Tundra body:
Installed with Hilux body:
Installed with F-350 body:
What's included:
Requires: 1x Motor (35T to 55T), 1x ESC (Z-E0007 or Z-E0006), 1x 2/3 channel Radio (part # X-10001), 1x servo (part # X-0502), 1x battery and 1x charger.
Important Note: This truck kit is designed to fit Tamiya Hilux, F350, Tundra body or other lexan type of bodies. .
This truck will require 1-2 hours of build time. And lexan panel require painting.
Instruction Manual:
Not available yet....
International customers (Non US)
If you plan to order this kit, make sure you choose EMS as shipping method.
Important Note:
This is a pre-built crawler, changing tire or wheel type is not possible.
Optional Upgrade
Hardcore diff cover (Part # Z-S0012)
Rok-Trac diff cover (Part # Z-S0009)
TDK diff cover (Part # Z-S0013)
Chrome diff cover (Part # X-0055)
Billet front axle (Part # X-0095)
Billet rear axle (Part # T-Rex60RR)
$599.99
Meer crawlers hier te vinden : RC4WD - The Ultimate RC Products alleen maar prachtige crawlers !
Mvg
- Adjustable wheelbase
- Multiple shock mounting options
- Adjustable frame mounted servo ...adjusts front to rear and up/down
- Adjustable rock sliders. Adjust in/out and front to back to fit any body.
- Flat plates welded on, allows you to use them to mount the body to the rock sliders.
- Tabs on bottom of bed to bolt a floor panel in.
- Front bumper that can be adjusted front to rear and up/down with a plate to mount a winch.
- Scale rail chassis
- Tube welded chassis
- Black powder coated
- T-Rex plastic axles
- Gear Ratio: XX:1
- Rock Crusher 1.9 Tires with X3 compound (108mm/4.25inch tall)
- Dual spring billet shocks
- OEM Steel plated 1.9 wheels
- Spare wheels & tire included
- Full ball bearings
- Bulldog 9500XT metal winch
- Length: XX"/XXmm, Width: XX"/XXmm, Height: XX"/XXmm , Wheelbase: XX"/XXmm, Center ground clearance: XX"/XXmm
- Engineered by John Boyer in Pennsylvania, USA
What's included:
- 1x RC4WD 1/10 Boyer Truggy Kit
- 1x Bulldog 9500XT Winch
Instruction Manual:
Important Note:
Optional Upgrade
$599.99
Mvg
