het eerste rc-vliegtuig met een fuel-cell heeft enkele succesvolle vluchten gemaakt. Fuel cell air vehicle takes off The Hornet, DARPA's fuel cell-powered micro air vehicle, has made its first successful flight in Simi Valley, CA, flying three times for 15 minutes. The radio-controlled vehicle, collaboratively developed by Lynntech and AeroVironment, has a flying-wing design and sports a 15 inch wingspan. Its total weight when fuelled is just six ounces. As can be seen in the photograph, the fuel cell itself incorporates a stiff metal mesh that also functions as a mechanical structure to strengthen the wing. Hydrogen is stored in a dry, solid, pellet form. It is released when combined with water, which is also carried in the vehicle. When the hydrogen reacts with oxygen collected from the airflow over the wing, it produces electricity which powers the radio, servos, motor, pumps, and other systems. During the flight, the radio control system was used to control the aircraft's throttle, rudder, and elevator surface. An additional radio channel was used to modulate the rate of hydrogen release. The Hornet is being developed under DARPA's Synthetic Multifunctional Materials program, which is exploring materials that combine the function of structure with another critical system function such as power, repair, or ballistic protection. DARPA says that the next generation of Hornet could incorporate a simple autopilot and carry a colour video camera bron http://www.e4engineering.com/item.asp?id=48609&type=news&pub=de Dus over een paar jaar zijn we allemaal aan de fuel-cell in plaats van de Lipo's.
Ongelooflijk.......... Ik hoop dat we eerst zo ver zijn dat we het in onze auto´s kunnen gebruiken, maar dan zullen we eerst de Shell enzo wel moeten begraven. :wink:
Shell begraven??? Die lui zijn daar veel te slim voor. Als de fuel cell eindelijk echt goed bruikbaar wordt zullen zij heel snel overschakelen van benzine naar waterstof pompen.
ach er zijn ook nog steeds complete komplot theorrien die zeggen dat de grote oliemaatschpijen elke alternatieve energie bron verstopt houden om zelf meer olie/benzine te verkopen maar het is natuurlijk wel een mooie ontwikkeling. Vinze
Die komplot theorieen zijn er inderdaat en soms denk ik wel eens dat er waarheid in zit. Het is toch eigenlijk heel erg gek dat het zo vreselijk lang duurt voordat er eens een echte "uitvinding" op het energie gebied wordt gedaan :roll: . Zo af en toe hoor of lees je wel eens wat maar meestal loopt dat met een sisser af. Sommige dingen blijken achteraf toch te mooi voor woorden te zijn. Biodiesel is zo'n voorbeeld. Op zich werkt het prima en vrijwel elke diesel motor kan er (met soms een kleine verandering) op draaien maar waarom gebeurt dit dan niet :?: . Nou daar is een simpel antwoordt voor, er kan gewoon niet voldoen van gemaakt worden. Als je alle diesels in Nederland op biodiesel wil laten lopen heb je bijna twee keer zoveel landbouwgrond nodig dan er beschikbaar is :cry: . Dus geen graan meer verbouwen, geen bieten , geen uien en ga zo maar door. Alleen maar gewassen waaruit biodiesel gewonnen kan worden kunnen dan nog maar verbouwd worden. Dat is natuurlijk niet mogelijk dus is er voor biodiesel maar een heel klein hoekje van de markt over en moet de rest op "vuile" diesel blijven rijden. Dit verhaal gaat op voor heel veel "alternative" energie bronnen. Er is te weinig van beschikbaar of er kleven andere belangrijke nadelen aan. Als het echt zo is dat de olie over een jaar of 50 op raakt moeten we NU zuiniger aan doen met de nog beschikbare brandstoffen en verder moeten zoeken naar echt bruikbare alternatieven. Niet makkelijk maar wel hard nodig. :!: Dus als dit "systeem" werkt dan allemaal gaan gebruiken om onze accu's te laden. Scheelt weer zoveel KWuur per jaar.
