Ecstacy
PH-SAM
Nieuw: DJI E1200 PRO TUNED PROPULSION SYSTEM:
The E1200 is a fine-tuned propulsion system designed for multi-rotor copters weighing 7-15 kg. Extensive optimization provides efficiency, safety, and endurance under extreme conditions. This system can be used to upgrade platforms with 25mm-diameter arm tube, such as S900.
The Pro version adopts an integrated structure and a total solution for heat dissipation design. The 17-inch carbon propeller, together with 4216 motor and sine-wave drive ESCs with real time diagnostics, unlock vastly greater possibilities for professional aerial photographers.
Video: https://vimeo.com/123049566
De E1200 standaard versie met een conventioneel motordesign en separaten ESCs volgt later...
