Nieuw toestelletje van E-flite
FJ-2 Fury BNF Basic by E-flite - YouTube
Key Features
Easy to complete final assembly
AS3X® technology delivers rock-solid stability and great handling
Durable, lightweight Z-Foam™ construction
Authentic outline and scale details
Spektrum™ AR636A DSMX® 6-Channel AS3X® sport receiver, installed
Powerful 70mm EDF unit features a 15-size, 3700Kv brushless motor
60-amp 14.8V brushless ESC installed
Finely tuned ducting delivers a scale appearance
Six micro servos installed for aileron, elevator, rudder and nose wheel steering
Clear canopy, cockpit details and pilot figure
Removable fixed landing gear
Removable drop tanks
Needed To Complete
Full range 4+ channel DSM2®/DSMX compatible aircraft transmitter
High-power 3200mAh 4S 14.8V Li-Po battery
AC or DC 4S Li-Po battery charger
Included:
Spektrum™ AR636A DSMX® 6-channel AS3X® sport receiver (installed)
(6) E-flite® micro servos (installed)
15-size, 3700Kv brushless inrunner motor (installed)
70mm fiber-filled nylon EDF unit with 5-blade rotor (installed)
4S compatible, 60-Amp 14.8V brushless ESC (installed)
Material: Z-Foam
Wingspan: 36.75 in (933mm)
Length: 38.75 in (984mm)
Wing Area: 304 sq in (19.6 sq dm)
Flying Weight: 3.3 lbs (1.49kg)
Motor Size: BL15, 3700Kv
EDF Size: 69mm
Recommended Motor Battery: 14.8V 4S 3200mAh LiPo
Minimum Required Radio: 5 Channel
Servos: 13g
Minimum Speed Control: 60A
Speed Control: 60-Amp (installed)
Flaps: No
Retracts: No
Recommended Environment: Outdoor
F-86 Sabre op nieuw gespoten?
Key Features
Needed To Complete
Included:
Material: Z-Foam
EDF Size: 69mm
Servos: 13g
Flaps: No
Retracts: No
