Onderstaande "bind"procedure werkt niet (handleiding meldt ook R6014FS receiver only) maar hoe moet het dan?
1. Place the transmitter and the receiver close to each other within one (1) meter.
2. Turn on the transmitter.
3. Check the LED that is placed on the front side of the transmitter to see if the RF signal is active. When the blue LED is
ON solid, the RF signal is being sent.
4. Turn on the receiver.
5. Press down the Easy Link(ID SET) switch for more than one second, and release the switch. The receiver starts the
linking operation.
6. When the linking is complete, the LED in the receiver will change to solid green. Please confi rm that the servos will
now operate by your transmitter. Please refer to the table below for the LED status of the receiver's condition
linking operation.
