Zie hier een stukje uit de "guide" die je op onderstaande link vindt:
* Proportional mix and gyro gain
1. Turn gain to below half way. (Note: Full clockwise is max gain.)
2. Plug in 4in1 and wait for solid green light. (Make sure helicopter does not move during this stage)
3. Fly heli and note the direction of yaw.
4. Land and unplug the 4in1. (Must unplug 4in1 for changes to take effect.)
5. Adjust the proportional pot.
o If the nose was yawing right then decrease pot (counterclockwise).
o If the nose was yawing left then increase pot (clockwise).
6. Repeat steps 2 to 5 till the yaw is gone.
7. Fly the heli and increase gain till you experience some tail wag. (No need to unplug 4in1 when adjusting gain.)
8. If you do experience tail wag then decrease gain a bit till the wag is gone.
9. Changes in the gain may reintroduce some yaw. If so, repeat steps 2 to 5 again with the new gain setting.
Note: Make sure not to move the helicopter while the 4in1 is initializing. Always wait for the solid green light before moving it, otherwise the gyro may not calibrate correctly.
HoneyBeeFP - EFlightWiki
