Ik heb momenteel een Futuba 2PL AM zender en ik denk dat het tijd wordt dat ik deze vervang na bijna 10 jaar...
Heeft er iemand ervaring met de Graupner XG-6I race spec 2.4Ghz zender?
Is dit een goede zender?
Ik gebruik nu enkel de EPA en EXP...is er nog iets wat ik nodig heb op een zender...?
Alle tips zijn welkom...
The new XG-6i RACE SPEC three-channel radio control system from GM-Racing offers reliable 2.4 GHz technology combined with an unbeatable price : performance ratio. The clearly arranged LCD screen and wide range of practical adjustment facilities make it the ideal system for the ambitious racing driver. All the important controls are positioned within easy reach of the hands on the ergonomically efficienttransmitter case, enabling the driver to make adjustments even when the model is running.
2.4 GHz ISM system, eliminating plug-in crystals and channel selection processes
Immune to interference caused by electric motors and metal-to-metal "noise"
Short transmitter aerial, can be folded and removed
Ultra-fast transmission rate
Large, clearly arranged LCD data monitor
Sixteen model memories (with model name and copy function)
Two proportional channels and one switched channel (AUX)
Four-button terminal for programming all parameters
Programmable fail-safe
Digital trims
Servo reverse
Servo end-point adjustment (EPA) for all channels
Servo travel adjustment (Dual Rate) for the steering servo, range 0 - 120%
Sub-trim and Expo settings for throttle and steering servos
Brake mixer function for large-scale models
Anti-block system (ABS) for the throttle servo
Variable transit speed for the throttle and steeringservos Auto-Start function (ATS)
Throttle Hold for the throttle servo
Integral count-up or count-down timer
Transmitter battery low voltage warning with audible alarm
Transmitter charge socket
Foam rubber steering wheel for accurate steering
Specification
XG-6i Race Spec transmitter, 2.4 GHz
Frequency band: 2.4 - 2.483 GHz
Modulation: DSSS (Direct Sequence Spread Spectrum)
Operating voltage: 8.7 - 12 V
Current drain: approx. 300 mA (at 9.6 V)
Channels: 3, incl. one switched
Servo travel: 0 - 120 %, variable
Temperature range: 0 - 70° C
Specification, XG-6i receiver, Order No. 94000.1
Operating voltage: 4.8 - 6.0 V
Current drain: approx. 14 mA (at 4.8 V)
Dimensions: 38 x 25 x 16 mm
Weight: approx. 13 g
Digital trims
Servo reverse
Specification
