Handige modelbouw tools uit je printer.
onno10
PH-SAM
In navolging op het topic 3D printbare vliegtuigen lijkt het mij handig om een topic op te starten met allerlei modelbouw tools die je kan printen.
Het gaat dan niet over servohouders en dat soort dingen, maar b.v. een vleugelhoekmeter e.d.
https://www.thingiverse.com/thing:2020386
Edge Banding Trimmer
https://www.thingiverse.com/thing:2016991
Triangular Balsa Cutter
https://www.thingiverse.com/thing:1119075
rudder angle gauge
https://www.thingiverse.com/thing:591968
RC Plane Center of Gravity Balance
https://www.thingiverse.com/thing:1201234
Blade pitch gauge attachment for iPhone
https://www.thingiverse.com/thing:832507
RC Ride height gauge 15-30mm
https://www.thingiverse.com/thing:1391473
Damper and link balancer
https://www.thingiverse.com/thing:41972
45 Degree Angle Foam Board Cutter
https://www.thingiverse.com/thing:39261
Blade MCPX swash leveling tool
https://www.thingiverse.com/thing:2839739
RC Wing Hinge Slotting Jig
https://www.thingiverse.com/thing:262610
Swashplate leveling tool for 450 size rc helicopter
https://www.thingiverse.com/thing:1502069
Align T-rex 500 ESP setup tool
https://www.thingiverse.com/thing:2377173
RC motor trust scale
https://www.thingiverse.com/thing:2384404
Control Surface Sanding Block
https://www.thingiverse.com/thing:2495516
O.S. 50 Crankshaft Locking Tool - RHWM
https://www.thingiverse.com/thing:735422
Dash's hand sanding tool(deze vergroten of verkleinen)
https://www.thingiverse.com/thing:2806625
Prop balancer Fits on Multiplex C of G gauge #693054
https://www.thingiverse.com/thing:1730475
Angle of incidence meter
https://www.thingiverse.com/thing:1306531
magnetic building board-Short/Tall Right Angles Stepped Right Angle Small Magnets
https://www.thingiverse.com/thing:2199356
Center Finder For Edges Set
https://www.thingiverse.com/thing:1363418
CG balancer for RC planes
https://www.thingiverse.com/thing:2418379
RC Airplane CG Finder
https://www.thingiverse.com/thing:2570397
Prop drill guide for DLE30, RCGF30 and other RC gasoline motors
https://www.thingiverse.com/thing:2200659
RC Wheel and Tire Balancer
https://www.thingiverse.com/thing:756934
Prop Balancer
https://www.thingiverse.com/thing:2849190
Voor als je in de tuin moet werken en even niet mag bouwen...
Zo, ik heb ongeveer 3000 objecten bekeken en de gevonden links in het start topic gevonden.
Ben benieuwd naar de aanvullingen.
