HPI Baja 5B Flux
Hallo ik zit er over te denken om deze wagen te bestellen. Ik vroeg me af of er al meer mensen(gekken) zijn die de Baja Flux thuis hebben staan en wat ze er van vinden?????!!
We maken er dan maar een leuk begin topic zodat het ge ........ kan losbarsten
Groet Ronald
Large Scale Baja Fun with Massive Flux Power!
The Baja 5B Flux takes the stage as another large-scale release for HPI in 2012! This super-powerful, super-quick buggy can hit speeds up to 60mph with 8S power and a 780Kv motor! Powering this 1/5 Scale electric Baja is a Castle Creations Mamba XL2 ESC and 2028-780Kv electric motor that is 8s LiPo (33.6volts) compatible. With this powerful system and an 8S LiPo battery, there is nearly 10hp available right at your fingertips for immense speed and thrills!
The Baja 5B Flux is fully outfitted with the latest options, including the drivetrain parts from the Baja 5SC, adjustable VVC/HD shocks, 2.4GHz radio system and high-torque, large scale metal gear steering servo.
Completing the package is a new Baja 5B Flux-specific body with smooth, flowing body lines on both sides of the shell since there is no need for a fuel cap entry slot on the left side of the shell.
CASTLE CREATIONS MAMBA XL2 SPEED CONTROLLER
To handle the power and speed of the Castle Creations 2028-780KV motor in something the size and weight of the Baja 5B Flux, Castle came up with the Mamba XL2 speed controller - able to handle up to 8S LiPo (29.6 volts) and fitted with a huge fan to keep things on the cool side.
CASTLE CREATIONS 2028-780KV MOTOR
If you want to go fast these days, you need to go brushless. If you want to go CRAZY FAST, you need to fit the Castle Creations 2028 motor! This massive powerplant features 780KV of power - that's many times the torque of the motors used in our Sprint 2 Flux cars! You need a powerful motor to haul nearly 10 kilos of large-scale buggy through mud and sand, and this is precisely the motor for the job! With extra-thick wires, gold-plated connectors and cooling fins, the 2028 is the perfect match for the Baja 5B Flux.
LARGE BATTERY BOX
The 5B FLUX features a tool less easy entry large sized battery box capable of holding two hard case 4s LiPo packs or one 8s LiPo pack with an easy to reach opening for connecting the battery(s) and ESC together. We'll have battery packs soon that will be the perfect fit for the Baja 5B Flux!
Super Heavy Duty Parts
Because of the ever-increasing power demands of Baja owners around the world, and the constant desire to cram as much power in the Baja chassis as possible, we've added all-new SUPER Heavy Duty drivetrain parts that will make sure the Baja 5B Flux can handle extreme conditions and massive power!
Super Heavy Duty Drive Shafts
All-new extra-thick 9mm dogbones are the starting point of the 5B Flux drivetrain upgrade - these are new, thicker and stronger to outlast the roughest rides and racing action you can find! New wider rubber boots are included to keep the dirt and mud away.
Super Heavy Duty Diff Shafts
Getting the power from the diff gears to the new dogbones is a wider diff shaft that perfectly fits the increased diameter of the dogbones.
Super Heavy Duty Drive Axles
The Baja 5B Flux is fitted with new Super HD drive axles to get power to the rear wheels, which fit the thicker dogbones.
VISCOUS TORQUE DIFF
Unique in the world of large-scale racing, the HPI Viscous Torque Differential gets the power to the rear wheels as smooth as silk. It's easy to tune with optional diff oils and is fully fitted with hardened metal gears and an alloy case.
ALL METAL GEAR TRANSMISSION
From the input shaft and idler gear to the alloy-encased differential, every gear inside the sturdy Baja 5SC transmission is made from long-life alloy to keep your truck running all day long with minimal maintenance.
Features Summary
  • Pre-Assembled 1/5th scale Off-Road Buggy
  • Based on the Baja 5B Buggy
  • Castle Creations Mamba XL2 speed controller
  • Castle Creations 2820-780Kv motor
  • 6S and 8S LiPo compatible
  • New streamlined body design and graphics
  • TF-20 2.4GHz radio system with failsafe
  • Adjustable motor mount to fit option pinion gears
  • Powerful & waterproof SFl-11MG metal gear steering servo
  • Adjustable VVC/HD shock absorbers
  • Monocoque chassis
  • Long travel suspension
  • Viscous torque oil-filled gear differential
  • All-terrain tyres and beadlock wheels
  • Aluminium rear shock tower
  • Hard plastic skid plates
  • Adjustable rear wing
  • Quick access to all critical maintenance points
  • Dual bellcrank steering
  • Cam type servo saver
  • All socket head hardware
  • Gunmetal anodizing
  • Full set of rubber-sealed ball bearings
Natuurlijk ook de benodigde filmpjes!!
Gave auto, had die filmpjes ook al gezien, vooral betere achterbanden schijnt een must-have te zijn, maar verder super bak.
Lekker in de duinen crossen ;-)
Bij HK kan je voor niet al te veel geld banden bestellen.
Zo vrijdag ga ik hem ophalen!!!!
Meteen ff een vraag want ik moet er natuurlijk een paar nieuwe banden onder hebben om fatsoenlijk te kunnen rijden!! Waar kan ik het beste mijn baja onderdelen lees banden bestellen??? Helemaal geen ervaring met 1:5 onderdelen en ik heb begrepen dat er nog al wat speciale baja shops zijn in NL/D/B. Voor de duidelijkheid gaat hier niet om winkel geneuzel maar ff wat tips waar ik goed en serieus terecht kan. via pm mag ook hoor!!
Als ie binnen is natuurlijk de foto's enz........
Oja nog een vraag heb ik voor die Baja ander gereedschap nodig??
Groet Ronald
Je zou eens bij Die Rovan Spezialisten kunnen kijken, is Rovan spul maar hun banden/wielen doen mijnsinziens niet onder voor HPI.
Wielsleutel
Kruiskop schroevendraaiers
Imbus/torx set
Zo ik heb hem hoor!!!
Lekkere dikke motor!!
En dit is het complete pakketje :)
Zo vanmorgen met het slechte weer een beetje zitten zoeken naar wat lipo's. Ik heb hier nog wel het één en ander liggen maar wil toch wat bij bestellen is wel fijn voor een dagje strand!!
zit te denken aan deze:
2x
Capacity: 5800mAh
Voltage: 4S1P / 4 Cell / 14.8v
Discharge: 30C Constant / 40C Burst
Weight: 568g (including wire, plug & case)
Dimensions: 145x50x38mm
of deze maar die zijn niet echt bruikzaam voor andere auto's denk ik ivm de groote!!
2x
Capacity: 8000mAh
Weight: 845g (including wire, plug & case)
Dimensions: 166x69x35mm
Ik kan ook gaan voor 8S maar die zijn helemaal nergens anders bruikbaar voor. Ik wil ook nog een Losi 5t en een FG Baja kopen maar daar liggen de lipo's weer anders in volgens mij.
Alsje bij een 5ive t gaat dan moetj ook castle gebruiken endanis zelfste lipo's e.;)
En kijk eens naar gens ace ook goede en supergoede service i.v.m. Hobbyking......
En max amps zijnwel zot maar is super costelijk e...
Waar bestel je die Gens ik heb ze al vaker gezocht maar kan ze niet vinden.
Groeten Ronald
www.gensace.com (gaat gewoon via duitsland). Al 2x bij hun besteld en is binnen een dag of 2-3 binnen.
Mooie wagen trouwens :), veel plezier ermee zodra het weer een beetje mooier wordt.
Neen is europa dus geen invoers rechten!!!
En ik heb er liggen nog nieuwe gens ace 5800 mah 4 cells.
Ik rij ermee met vorza en gaan zeer lang mee..
Ben ook vanplan van in de toekomst een baja te kopen.
Grtzz
idd zoals damon al zei, geen extra kosten (naast verzenden natuurlijk :)). Zijn idd goede accu's en gaan lekker lang mee, daarintegen betaal je ook wel meer voor 1 gensace accu t.o.v. 1 zippy/turnigy.
Ja idd maar je betaald de service.
Ik heb 2 kapotte turnigy's die ik moest opsturen en die ik nooit meer heb gezien.
Ik heb in al die tijd 1 gens ace kapot gehad en had binnen de week een nieuwe..
Lekker het geluid van de wielen in het zand bij dat laatste filmpje geen muziek
Mooi ding veel plezier
Grts
