Hummingbird elite pro 3d, nou wat vinden we ervan?
Lijkt mij een goeie heli, maar wat vinden jullie er nou van?
Dus heb je info, ervaring ermee, etc. laat het dan even horen.
Helpt je mij ook weer :wink: , want ik ga hem misschien in de zomervakantie kopen :)
Tja, hier zal je weinig ervaringen krijgen vrees ik. Heb er nog niemand over gehoord.
Ondertussen heeft Century al 2 update's gedaan aan de heli. De Skids zijn versterkt er er is een extra lager ingekomen. (deze updates zitten in alle nieuwe kits en zijn ook gratis te krijgen voor degene die een oude kit heeft)
uit het draadje "3D Pro, Have there been any problems yet?" op runryder:
wilsonj zei:
The pro has a few probs, but to Century's credit they are on the ball with rectifying them. Problems listed below
1. Skids break easy.
Solution. Century have a new thicker stronger skid available, and it comes with new kits.
2. Tail gearbox rotates on boom.
Solution. New thicker gearbox around key area. Although I haven't seen this yet.
3. Some of the crown gears are very tight.
Solution. Either quality control is low on this part, or they have made a change, as some say theirs fit perfect. If it doesn't just trim some plastic off the top.
4. Tail gear mesh very sloppy.
Solution. Some don't have this problem. Again maybe a quality control issue? To fix it just trim some of the steel sleeve and move the gear closer to the other one.
5. Tail output shaft gets stuck.
Solution. Oil it before use and keep checking it. A drop of oil every flight isn't a bad idea. Also grease the gearbox.
6. Tail bladegrip lets go.
Solution. None yet. So far this has happened to a couple people. Doesn't seem wide spread though. It is a problem with the bearing failing under load. Really a thrust bearing is needed here. But this would require major redesign of the grips. Or maybe better quality bearings.
Thats about it.
As far as how it flys. So far most are very happy. Me included.
The stock motor is fine for sport flying and mild 3D. Flips rolls etc. It doesn't have the power for tic tocs and the like. Not on 3S anyway. The pinion it comes with is a 10t. Seems to be about right.
I am currently experimenting with an axi on 4s. Boyd has tried it with good results. I hopefully will have more info on that on the weekend.
Hope this helps.
Regards
Jamie Wilson
Verder hoor ik veel positiefs erover :)
Hey,
Ik had het gelezen ja, dat mensen die een 'ouwe'versie hadden, de verbeteringen gratis kregen. Een mooi gebaar :D .
Is die nu eigenlijk al verkrijgbaar in Europa, ik heb die heli nog nergens
gezien... :?
Ziet er wel leuk uit ! 8)
Groeten
Steven 8)
Min bestelling bij home-flyer loopt al van vorig jaar..... snif snif....
Duurt al zo lang, ben ondertussen (op goede vrijdag) nog papa geworden ook....
Waar ga ik de tijd vinden ALS hij binnenkomt? ;-)
Hartelijk gefeliciteerd !!! :lol:
Is het een meisje of een jongen ? :)
Vriendelijke groeten
Steven 8)
er staat bij homeflyer"levering onderweg"al enkele maanden... :?
jammer,wacht er ook op...
Hier word hij ook verwacht,
Midland Helicopters / Coming Soon
Introducing the ultimate choice in aerobatic capable super-micro electric R/C helicopters, the Hummingbird 3D Pro! This model is 3D capable right out of the box. Expect only the best as you experience tight, precise control and quick response as the Hummingbird 3D Pro will dazzle you with agility and speed. Using the basics of micro electric design to keep componets light and durable while distributing heat away from electronics, the Hummingbird 3D Pro is not only precise, but also efficient. When you combine precision and efficiency and add beauty, you will arrive at the Hummingbird 3D Pro: The Ultimate Super-Micro 3D Electric Helicopter. This version includes the Century Brushless Motor & Speed Controller also. Due for release soon.
