M
Maybe
I.p.v. van Flightpower 3S1P EVO25 2170mAh maak ik nu gebruik van Kong Power 3S1P 2200mAh Li-Po's
Op RunRyder kwam ik onderstaande Kong Power 3S1P 11.1V 2200mAh test tegen, oordeel zelf.
Well I put a 11.1 2200 threw an extream test today.
Heli straped down (450se with XL motor and X speedo) Set timer on radio for 6:30 seconds and went full pitch (11.5) in stunt 3 and let it run for the entire 6 1/2 mins.
Results
Motor temp 121.5
Speed control temp 103
Pack temp 112-115 average around the pack highest was 115
Head speed first min 3210rpm
Head speed 5:30 3100
Head speed 6:30 2950
Mils put back into pack 1825mah
pack was charged and balanced balanced within the first min (Flight power) balancer
Voltage before charge was 9.9volts
Voltage after charge was 12.6volts
Pack #2 same test as above but with + and - pitch in the machine with loading of the tail.
Head speed at start 3200
Head speed at 5:30 3000
Motor Temp 121.5
Speed control temp 103.1
Battery temp 113 115 118
Voltage when started charging was 9.5volts
Mah put back into pack was 1943 voltage charged to was 12.6v
Balanced with Flight power Vbalancer balanced with in 1 min while charging.
These tests were done with full pitch + and - with loading of the tail 30 sec. at a time.
Well I did the same above test with a flight power battery 25c 11.1 2170
Test results:
Head Speed at start first min 3210
Head Speed at 1min 3090
Head Speed at 2mins 2870
Head Speed at 3mins 2850
Head Speed at 4mins 2190
Head Speed at 5mins 1920 this is where I stopped test, noticable lack of power
Motor temp 125
Battery temp 120-125-118
Speed control temp 105
Voltage at start of charge 8.6volts
Time to Balance using Flight Power Balancer over 1 hour
Mils put back into pack 1690
