Making a MW54
  • Topicstarter Topicstarter Edimar
do you have the right number then?
i hope you did order the right one.
let me know when you have it.
Barry is a fast shipper
Nice Edimar, your own topic ;)
I told Edimar to ask barry for the comrpessor wheel for the Wren MW54, I am not sure if barry is aware to send the 12 balde comp. But, i asked barry for the same component, not mentioning 12-blade or so, and i got the right one ;)
Good luck building Edimar!
Best regards,
Rik
Best regards,
Rik
Hi Rik!
Very good your topic.:worship:
I learn a lot there
thanks
Edimar ,this is the original wren diffusor wren uses in the engines now.
Hello friends!
I'm thinking in the electronics of the turbine. Thus I saw the possibility of buying of Wren or Xicoy.
There is some damage in terms of software if I buy directly from Xicoy?
You can buy directly from Gaspar (xicoy) no problem.
if you want to buy an ecu , buy the new v10.
its a great ecu .
Regards,
Martin.
there is a warning though:
IMPORTANT NOTE: These units are supplied "blank", not programmed for a particular engine. Xicoy Electronica DOES NOT supply fadecs already configured for to be used directly to a "brand xxx" engine. Contact your engine manufacturer if you need a fadec already programmed for your engine.
should you contact wren for this?
edit: damn, they don't have my Fadec main unit manual start anymore.. :(
B.R
Rik
B.R
Rik
So, it is precisely for this note I made to my question.
In this FADEC, between what I buy XICOY or WREN, the only thing that changes is the parameter settings, is it?. The Software is the same, is it?
Hello friends,
Today I received the compressor wheel with 12 blades :cool:
full
Hi builders:D
What is the voltage of the solenoid should I buy, for 6v or 12v?!:confused:
I find both the site of Xicoy.:!:
thanks
