Pianodraad dus:Piano wire is a specialized type of wire made for use in piano and other musical instrument strings, as well as many other purposes. It is made from tempered high-carbon steel, also known as spring steel. Music wire is another name for piano wire: it is used for the cores of strings, which may be wound with other materials. Music wire is used for a variety of stringed instruments that use steel strings, such as guitars.
Oftewel: verenstaal.pianodraad
Hoogwaardig, gelijkmatig staal dat wordt gebruikt voor het maken van speciale veren.
wat is music wire in nederlands?
