middels het set commando nu alle opties gekregen, hier mijn settings. (tevens voor mezelff om later terug te kunnen halen) # set Current settings: looptime = 3000 midrc = 1500 minthrottle = 1100 maxthrottle = 2000 mincommand = 1000 mincheck = 1100 maxcheck = 1900 deadband3d_low = 1406 deadband3d_high = 1514 neutral3d = 1460 deadband3d_throttle = 50 motor_pwm_rate = 400 servo_pwm_rate = 50 retarded_arm = 1 flaps_speed = 0 fixedwing_althold_dir = 1 reboot_character = 82 serial_baudrate = 115200 softserial_baudrate = 9600 softserial_1_inverted = 0 softserial_2_inverted = 0 gps_type = 1 gps_baudrate = 0 serialrx_type = 0 telemetry_provider = 0 telemetry_port = 0 telemetry_switch = 0 vbatscale = 110 vbatmaxcellvoltage = 43 vbatmincellvoltage = 33 power_adc_channel = 0 align_gyro = 0 align_acc = 0 align_mag = 0 align_board_roll = 0 align_board_pitch = 0 align_board_yaw = 0 yaw_control_direction = 1 acc_hardware = 0 max_angle_inclination = 500 moron_threshold = 32 gyro_lpf = 42 gyro_cmpf_factor = 600 gyro_cmpfm_factor = 250 pid_controller = 0 deadband = 0 yawdeadband = 0 alt_hold_throttle_neutral = 40 alt_hold_fast_change = 1 throttle_correction_value = 0 throttle_correction_angle = 300 rc_rate = 90 rc_expo = 65 thr_mid = 50 thr_expo = 0 roll_pitch_rate = 0 yawrate = 0 tparate = 0 tpa_breakpoint = 1500 failsafe_delay = 10 failsafe_off_delay = 200 failsafe_throttle = 1200 failsafe_detect_threshold = 985 rssi_aux_channel = 0 yaw_direction = 1 tri_unarmed_servo = 1 gimbal_flags = 1 acc_lpf_factor = 4 accxy_deadband = 40 accz_deadband = 40 acc_unarmedcal = 1 acc_trim_pitch = -2 acc_trim_roll = 0 baro_tab_size = 21 baro_noise_lpf = 0.600 baro_cf_vel = 0.985 baro_cf_alt = 0.965 mag_declination = 2500 gps_pos_p = 11 gps_pos_i = 0 gps_pos_d = 0 gps_posr_p = 20 gps_posr_i = 8 gps_posr_d = 45 gps_nav_p = 14 gps_nav_i = 20 gps_nav_d = 80 gps_wp_radius = 200 nav_controls_heading = 1 nav_speed_min = 100 nav_speed_max = 300 nav_slew_rate = 30 p_pitch = 42 i_pitch = 30 d_pitch = 23 p_roll = 42 i_roll = 30 d_roll = 23 p_yaw = 80 i_yaw = 45 d_yaw = 0 p_alt = 50 i_alt = 0 d_alt = 0 p_level = 90 i_level = 10 d_level = 100 p_vel = 120 i_vel = 45 d_vel = 1
acc_lpf_factor = 100 dit maakte het verschil tussen wobble en strak, waar de pid`s eerst omlaag moesten gaan ze nu omhoog mn tri vliegt nu mooi strak
Klopt, is een enorm verschil.. En inderdaad kun je daarna de pids wat omhoog gooien en krijg je dat hele locked in gevoel..
Snap niet dat die lpf factor op 4 staat: Waarom? Gister getest met 100 Wat een verschil... Pids wat omhoog inderdaad en super stabiel
slecht wegdek Hallo allemaal, ik heb een DJI phantom 1.1 en ik heb afgelopen dagen toen het windstil was een paar filmpjes gemaakt maar als ik het resultaat bekijk is het net alsof ik over een hobbelige weg rij zo waggelt dat ding . Is hier iets aan te doen of weet iemand waar dat aan kan liggen.
Hoi, Mijn Naze32 op mijn mini250 quad drift na verloop van tijd. Dus in eerste instantie vliegt hij mooi level en zonder drift in Angle modus. Langzamerhand ontstaat er een drift naar achteren, die na 5 minuten enkele graden is geworden. Als ik land, disarm, en weer arm en vlieg is de drift nog aanwezig. Als ik de power uitzet en weer aan dan is de drift weer weg. Ik heb de motoren en props al gebalanceerd. Specs: - Naze32 - RCX 2400kV motors - 250size H frame - an 10amps ESCs SimonK Ik lees iets over de acc_lpf_factor; zou dit iets kunnen betekenen voor mijn probleem? Ik snap (ook) nog niet wat het doet! Wie biedt hulp?
Heb je de nieuwste firmware met baseflight al eens geflashed? De instellingen eerst bewaren met "dump" in de CLI en dan net copy past weer terug zetten
Ja, Ik heb versie 2.3 via baseflight erop gezet. Ik kan niet zo snel zien wat de actuele versie is maar deze heb ik er een maandje geleden op gezet dus lijkt mij aardig recent?
Is helaas niet te zien, voor de zekerheid de nieuwste erop. Acc calibratie ook uitgevoerd? De acc lpf factor staat als het goed is op 100 in de nieuwe versies, stond eerst laag op 4. Staat het bordje wel level? Is de balans op de quad goed?
