An online graphing tool for DC motors and propellers www.mshtests.co.nf/motor_plots.html Announcement www.rcgroups.com/forums/showthread.php?606703-e-flight-calculators-(compilation)/page11#post40365587 Highlights Several plots can be drawn simultaneously Parameters can be set to change automatically Any value can be used as an X-axis Plots can be viewed vs throttle position Simulation can be done with altering propeller properties and diameter Plot can be saved/shared via “generate link with parameters” Meer e-flight calculators, prop- en motor-databases E-flight calculators (compilation) - RCG Motor Data - test bench data for several hundred brushless motors - RCG
If someone wants to run it offline, he has to save the Chart.bundle.js utils.js chartjs-plugin-datalabels.js from the same url to his own folder or directory. Uit/van www.rcgroups.com/forums/showthread.php?3150967-online-graphing-tool-for-DC-motors-and-propellers
