gyro reverse
dit lukt niet,als ik de roll pod of de yaw pod of de pitch pod op null draai gaat het lampje niet knipperen?????? heb de pod ook andersom gedraaid ,maar nada!?:sad: vergeet ik wat?
groeten helij.
6. Checking gyro directions:
- Take off the propellers.
- Turn on transmitter and flight controller.
- Set throttle to about 1/4. Motors should start.
- Tilt multicopter forward. Forward motor should speed up. If not, reverse pitch gyro.
- Tilt multicopter to the left. Left motor should speed up. If not, reverse roll gyro.
- Turn multicopter CW. Front and back motor should speed up. If not, reverse yaw gyro.
7. Reversing gyros:
- Set roll gain pot to zero.
- Turn on flight controller.
- LED flashes rapidly 10 times.
- Move the stick for the gyro you want to reverse.
- LED will blink continually.
- Turn off flight controller.
- If there is more gyros to be reversed, goto step 2, else set roll gain pot back.
groeten helij.
7. Reversing gyros:
