P1 Puma RIB racing-scratch building
Thank you unusual! I add dimensions on the plans and fortunately they are 100% accurate!
To be honest I prefer cutting the templates by myself.
Unfortunately it is not possible to flatten a surface in Fusion 360. It would be very useful for skinning.
That is the downside of free software. It might be possible in Fusion, however it could be a feature you have to pay for :(
I know it can be done in Inventor, solid edge and SolidWorks (not the basic versions)
A work around can be making use of the sheet metal functionality. However you are then limited to single direction curved surfaces.
Having the ribs printed 1:1 is already a huge plus.
Flatten the surfaces for making the plating contours is in my opinion not a huge added benefit. I never used it, although I know the feature. By hand building, you will always find some imperfections. Using paper and cardboard for making templates of the plating works maybe even better in that case.
I tried my new mini table disc. I cut the transom using 4mm plywood. Very satisfied, it is fast, accurate producing very clean cuts. Some photos...
This is very Interesting Jan. I thought that having the flattened surfaces would be a huge benefit to speed up the process and improve accuracy but I was wrong. Good to know, thank you.
This mini saw table was a bargain?
Indeed a nice addition to your hobby-cave ;)
I have seen them from Proxxon among other, high quality but also it breaks your bank!
Yeah sure. One of the best buys I ever made. 63 € full aluminum, 4-5 extra disc's and highly accurate. Proxxon is about 4 times more expensive at least here in Greece. High Chinese quality :yes:
Update #2
Construction of the building board.
Step 1: Printing the top view in multiple A4 papers using Fusion 360 (for those interested in how I print my plans in A4 printers, see also a useful video:
a) Make a sketch with the required number of rectangles to cover the full top view of the hull using the dimensions of an A4 paper (210 mm X 297 mm). Be sure that the rectangles overlap each other, e.g. :
b) Then File -> New drawing -> From Design then on the new tab, Create Drawing, select Sheet size: A4
c) Adjust the plan so as the rectangle coincides with the A4 paper, e.g.:
d) Then File -> Print and you can either print as pdf and save it or send it to the printer. Here the first piece of the drawing on pdf:
To be continued...
Step 2: assemble carefully the A4 papers on a piece of plywood securing with tape and checking the length.
Step 3: cut pieces of plywood and screw on the board exactly where the ribs should be according to the plan.
Step 4: cut another slice of plywood to secure the ribs.
Step 5: do that for another x times where x is the # of ribs... :confused: (a for loop :D)
Thank you guys for your patience, have a nice Sunday afternoon..
Nice work Dim. It seems you did not draw the stringers (wooden reinforcement lath) in the ribs. Wil you add them later on?
Also, I think it wil be a challenge to make a tapered tube with the shape already in the wooden ribs. How will you make them? Skin between the ribs with wooden strips, or hard foam?
I don't mean to criticize, just some questions to keep you sharp:) You add a lot of nice activity / projects in this forum!
You are right Jan. I didn t manage to draw them even if I wanted to. For some reason the sweep did not work properly in Fusion...:confused:. You know I am still a beginner...and some things I try they just don t worko_O. I don't know if I add them later.
Regarding the tubes I am planning to add hard foam between the ribs and sand them down carefully to the wooden part just like cosy. I have done something similar at the beginning of the project with balsa and seemed to work nicely (see my first photos)
I think that the hard foam will strengthen the hull and maybe the stringers are not necessary. Moreover, I am planning to apply fiber and epoxy on both sides of the hull plus the ribs are quite dense. I also plan to fill with polyurethane foam at the bow. All the above-mentioned I think that will strengthen the hull.
No worries Jan, I do not take it as critisim but as sharing opinions and experiences. ;) thank you for your nice words.
Update #4.
I cut a number of 4x3 stringers with my mini table saw to enhance the hull as discussed with Jan and I also cut some more ribs. The plans changed slightly to account for the stringer cuts to the ribs.
I left the center stringer into the water overnight to be able to bend it smoothly.
I love it when your CAD model comes to life in the real world!
Most of the time I am shocked by the true size ;)
From a screen or a 2D print it is still hard to get a good feel of the true size
