P1 Puma RIB racing-scratch building
I love it when your CAD model comes to life in the real world!
Most of the time I am shocked by the true size ;)
From a screen or a 2D print it is still hard to get a good feel of the true size
You are absolutely right Unusuall!!! Especially without the tubes the hull looks so small.
Nice work on the tubes! Great project, it must look nice on the water when finished
Thanks Jan! The tubes must look nice and smooth when finished, they are key component of the hull.
I am also planning a homemade outboard for this hull using the cover I am preparing for the mini tfl :)
Update #7
Time for planking.
I use 1mm ply and solid balsa for the nose.
The keel needs reinforcement and an effective way to close the gap between the two sheets.
I worked as follows. First, I chopped some residual carbon fiber with the rotary cutter.
Then, I mixed the chopped fiber with epoxy resign (27 gr) and I applied to the middle of the hull with my finger or a piece of wood.
Update #9
The inner of the hull is laminated with 180gr/m2 carbon fiber.
First, I aplly a layer of epoxy resign and I let it cure for 2-3 hours.
Then I laminate with cf applying pressure by hands and I let it another 6-7 hours to cure.
Finally, I apply a final a layer of epoxy resign.
Great to see this build Dim! It becomes a really nice hull and something different from the more regular V hulls[emoji106]
One note: the epoxy layer after curing the laminate has no additional benefit for strength. Actually, less epoxy is better if I read from the experts. On the other hand, it does work for sealing the hull.
Looking forward to the next updates. In a few months boating season starts again!
Thank you very much Jan!! I really want to have the boat ready till the summertime but it seems a bit difficult.
I am very curious about its sailing behaviour especially on rough sea.
Maybe I did not express myself correctly.
The first layer of epoxy is applied on wood and after 2 3 hours when it is sticky enough I apply the CF. Thus, the first layer of epoxy is only to stabilize (glue) the CF on the hull and bend more easily over the corners, at this stage the CF is not laminated. In the final step, I apply epoxy resign on the CF which is glued on the hull.
But you are right, I generally try to use as less epoxy as it is feasible.
