Panorama, hoe het wel moet! ;)
Ik wilde het jullie niet onthouden:
Dit is PhotoshipOne.
I've been shooting 360 spherical panoramas for about 4 years now. Until today I have done them with a 700 class electric RC helicopter, a DSLR with 10.5mm fisheye lens and a custom designed camera mount ( our VR360 mount). The DSLR would pan and shoot a series of 6 images for a full 360.
The method mentioned above weighed about 13lb all up ready to fly. A bit heavy for certain missions where safety is of major concern. A 13lb rc helicopter can do tremendous damage to persons and property upon impact.
Also the DLSR method took about 3-4 seconds to capture. An rc helicopter can move quite a but in 4 seconds, even at the hands of a very good pilot. A movement of even 3 feet could create some bad parallax errors when it came time to stitch the images.
The need for a lightweight aerial panorama system which could capture all the images in less than one second was obvious but I put the idea off until a few weeks ago.
I had a few GoPro HD cameras laying around and had been impressed with their still photo quality considering the small size of the camera. I wondered if it woudl be possible to mount multiple GoPro cameras in a radial array to capture all the images simultaneously.
I decided on 5 cameras in an upside down pentagon pyramid array. This would provide the proper overlap between images. I modified the cameras to be triggered within about 1 second of each other and wired power from the copter to each one to eliminate the need for a battery in each camera. I created a power/trigger PCB distribution board with a voltage regulator to bring the copter 14.6v down to 5v. A capacitor was also added to the board to help filter voltage fluctuations.
Having flown several test flights today I can say it certainly works and works WELL!
Some samples below:
http://photoshipone.com/Superstition_Springs_1.mov
http://photoshipone.com/Desert_1.mov
Here's a shot of the rig in flight. All up weight, 4.1lb (1.9kg)
Gewoon even 5 gopro's aan een stokje.
Weer eens wat anders? :lol:
Dat is al 1500 euro aan camera's.
En dan nog een octocopter...
't Zal een afwijking van me zijn, maar ik heb op allebei die panorama's gezocht naar de schaduw van de octocopter en niets gevonden. zou hij die weggeshopt hebben?
In welke winkel shop jij? Ik zie voor 900 euro cameras. ;)
Maar toch, moet er niet aan denken dat zon ding een sloot in mieterd. :o
Ik denk dattie zijn schaduw weggepoetst heeft,
dat soort geintjes doen ze met de google streetview auto ook.
Volgens mij kost een GoPro HD ongeveer 300 euro. Maal 5 = 1500 euro.
Nou heb ik wel het idee dat deze man het professioneel gebruikt. Als platform voor professionele (panorama)fotografie is het geen kapitaal.
Het wegpoetsen van de Streetview auto schaduw gebeurt wel heel rudimentair... :(
Hier is er gewoon helemaal niks van te vinden, terwijl je door de schaduwen van palmen en lantaarnpalen toch vrij nauwkeurig kan bepalen waar hij ongeveer zou moeten zitten...
Kortom, netjes (professioneel) gedaan. Als Google nou eens die streetview foto's met dit ding ging maken... :cool:
Das wel een leuke winkel dan. ;) Ik heb die van mij geimporteerd voor 180 euro.
En inderdaad, google moet aan de slag met microdrones. :p In een ander topic was er al zoiets dat gewoon een hele 3D map optrommeld uit een serie fotos van een camera drone.
Ik heb er zelf geen... wel een jaartje geleden heel erg geaarzeld of ik er een zou kopen.
Tja als je zelf importeert dan betaal je de invoerrechten ook weer aan jezelf en dan verdien je er nog wat aan :yes::yes:
