Zo wordt het wel omschreven bij de kit, tenminste ik neem aan dat ze met flybarless kit de head ook bedoelen
. Je had ook al unboxing video's zitten kijken ha ha. Anders gewoon de winkel eens mailen
MSH Protos 500 Flybarless Carbon Combo kit MSH51104-FBL
S Heli Protos - Carbon Frame Protos 500 Combo inc motor/esc/Blades This is the
CARBON Flybarless Kit
Kit includes
MSH Carbon Main Blades
New MSH YGE Controller
Scorpion Motor made specifically for MS Heli.
MSH 500 Protos Specifications
- Mainblade size: 415mm-430mm
- Maingear: 97T
- Pinion: from 15T to 20T - (15T Included in the kit)
- Innovative single belt drive (motor->main gear->tail)
2mm flybar, Gorilla Gear programmable paddles
- 4mm tail grip root
- 1520g all-up-weight (AUW) with a 6s lipo 2500mAh
- 17mm OD aluminum tail boom
- Supports mini sized servos having 2 mounting holes or 1 mounting holes
- LiPo from 4S (~3700mAh) to 6S (~2500mAh)
- A123 7S 2300mAh humpback slab pack (2 cells over 5 cells). The auw becomes ~1700g
- Metal hub, metal swashplate, plastic tail box, main grips and tail grips
- Programmable flybar:mainblade ratio
-Flybarless upgrade included
- The tail grips with integrated Chinese weights so even with a mini size tail servo can have the same performance as a full size tail servo
- Frame material: Carbon Fibre
- Gorilla Gear landing gear
