Quote van Wolfgang:
What are the PC-requirements?
A regular Pentium 4 or similar at 1200 MHz will be fine. The video card is important. The minimum is a 32 MB hardware accelerated AGP 2x card with fast videa ram. A PCI card is unsuitable as much as a budget RAM card like the "MX" types. This video card should be DirectX 8.1 compatible. The best solution is a Geforce 5900 Ultra card or a Radeon 9700 Pro chip with 128 MB DDR RAM. As the number of combination in the market is getting very high, some combination may not work even if every component is matching the requirements. Things like slow front side bus or outdatet BIOS versions could be limiting the performance.
End Qute
Ziet er naar uit dat Marcel toch wat meer nodig heeft dan een nieuwe GrafKa.
Groetjes,
Rick
