heeft iemand ervaring met het instellen van een Scorpion 6-cell Switching BEC - 90 Amp Sw
No Function is Available
zo ja graag julie mening de motor is een aling 500 stock
alvast bedankt
Example from
Above
Above
095 Sets Low Voltage Cut to 9.5Volts
LVC 15V ESC
(Low Voltage Cut)
(Low Voltage Cut)
050-138 Low Voltage Cut 050 (5V) to 138
(13.8V) in 0.2 V increments.
*6V
*6V
LVC 26V ESC
(Low Voltage Cut)
(Low Voltage Cut)
050-230 Low Voltage Cut 050 (5V) to 230
(23V) in 0.5 V increments.
*6V
*6V
BRK
(Brake Setting)
(Brake Setting)
1*
2345
*No brake
Very soft brake
Soft Brake
Hard Brake
Very Hard Brake
2345
*No brake
Very soft brake
Soft Brake
Hard Brake
Very Hard Brake
PCT
Program Cut Type
(LVC type)
Program Cut Type
(LVC type)
1*
23
Cut 50% of maximum power
No Cut just LED warning
Pulse warning
23
Pulse warning
CAR/B
Car/Boat Mode
Disable Disable
COP
Current Overload
Protection
1*
2
Protection on
Protection o (this option will void
warranty)
Protection
1*
2
Protection on
warranty)
FREQ
Drive Frequency
1*
2
3
8khz (recommended for most
Brushless motors)
18khz (for use with low inductance
motors)
32khz (for use with VERY low Inductance
motors)
1*
2
3
Brushless motors)
motors)
motors)
SS
Soft Start
1
2
Heli mode with soft start, Variable
throttle* adjustable Soft start.
Heli mode with soft start and
governor. (See Governor Section)
1
2
RO
Motor Rotation
Direction
Direction
TIM
Motor Timing
1*
23456
Auto Timing
5°
15°
20°
25°
30°
1*
23456
Auto Timing
5°
15°
20°
25°
30°
SB
Motor Start Booster
1*
23
Soft
Medium
Strong
Soft Start Duration
1
2*
3
Short 10 Seconds
Medium 15 Seconds
Long 20 Seconds
1*
23
Soft
Medium
Strong
Soft Start Duration
1
2*
3
Short 10 Seconds
Medium 15 Seconds
Long 20 Seconds
GOV
Governor Correction
See section 9.0
1
2*
3
Soft
Medium
Hard
2*
3
Soft
Medium
Hard
ENTER
Enter value send signal to ESC
OTHER
All other keys are reserved for
future programming options
MAT
Motor
Acceleration Time
Delay
Motor
Acceleration Time
Delay
1*
2345
0.15 second
0.3 second
0.45 second
0.7 second
1.3 second
2345
0.15 second
0.3 second
0.45 second
0.7 second
1.3 second
AIR
1* Activate Airplane mode
*Factory Default
To reset all parameters to Factory Default:
*Factory Default
alvast bedankt
