Heeft er iemand ervaring met Sovol 3D printers? Wat denken de experten over de eigenschappen van de nieuwe SV06, en onderdelen hiervan? Graag jullie visie hierover. https://sovol3d.com/products/sovol-sv06-direct-drive-3d-printer?variant=40106603806808 Features of the Sovol SV06: 1. PEI Flexible Build Plate, easier to adhere and remove the models. 2. Upgraded Planetary Dual Gears Direct Drive Extruder. With a higher drive ratio and more accurate extrusion; Supports more materials including software and high-temp filaments like PLA, TPU, PETG, ABS, ASA, Wood, NYLON, PA, PC, and CARBON FIBER. 3. All Metal Hotend, supports high temp printing and better printing quality. 4. 25 Points Auto-Leveling, more accurate and quicker auto leveling. The FIX_MOUNTED_PROBE function is enabled and it takes less time for leveling. 5. 32-bit silent mainboard with TMC stepper drivers, more functions available in the firmware such as SENSORLESS_HOMING, FIX_MOUNTED_PROBE. More possibilities for upgrading the 3d printer. And the printing environment is also quiet, less than 60DB. 6. Dual Z axis, provides more stable Zaxis movement. 7. Belt Tensioners to make it easier for adjusting the belts. 8. Better Resume Printing function, continue to print and the printing result will not be affected by the power outage. 9. Refined Appearance
