heeft er soms al iemand ervaring met deze ?
Spirit Fun RTF is primarily intended for the “advanced beginner”. Our intention with this helicopter is to attract pilots who have gained initial experience with simple models such as co-axial helicopters. The model is supplied fully factory-assembled, is complete with transmitter, Lipo flight battery and charger, and can be prepared ready for flying in a very short time. No programming of transmitter, speed controller or gyro is necessary, as all adjustments are carried out by the manufacturer. Simply insert dry cells (not included) in the transmitter, charge the flight battery, and fly.
Specifications:
Main rotor diameter: 630 mm
Tail rotor diameter: 152 mm
All-up weight: 530 g
Height: 210 mm
Length: 600 mm
RC functions:
Roll
Pitch-axis (elevator)
Collective pitch
Tail rotor
Motor speed
Kit contents:
Factory assembled Spirit Fun model helicopter with receiving system, brushless motor and speed controller installed
Gyro system installed and connected
Six-channel FM computer transmitter with screen
Lipo battery, 11.1 V / 1300 mAh
Lipo charger and mains PSU
Training landing gear
CD flight simulator + USB lead for flight simulator
The flight simulator included in the set provides a means of practising helicopter flying on-screen before actually flying the model. A training landing gear is also provided. The six-channel FM computer transmitter is designed to be used with different types of model, and provides a total of four different menus for fixed-wing models and helicopters.
Specifications:
Height: 210 mm
Length: 600 mm
RC functions:
Roll
Collective pitch
Tail rotor
Motor speed
Kit contents:
