Eventjes ter info voor de t-rex 600 vliegers .
T-REX 600 Problem
Sunday, August 6, 2006 | Printer Friendly
To our customers- Who ever purchased TREX 600, please send us pack the blade grips, we will send a replacement in return -------------------------------------- Info received from Align We have discovered a critical safety issue on the T-Rex 600 and hereby issue this safety bulletin. Abnormal fracture line has been discovered on T-Rex 600 main blade grips during post-flight inspection. With the T-Rex 600 mass produced and readily available, more variation in setups and power combinations are attempted by pilots in real life situations. We have unexpectedly discovered some abnormal fracture lines on blade grips in certain instances. Upon further investigation at microscopic level, our technical department has found the blade grip’s structure integrity to decrease dramatically with the presence of these fracture lines. Flying with these fractures at high headspeed with 11T pinion may lead to breakage of blade grip. This problem was not detected during our long-term longevity and stress tests since the tests were done with stock power setups. We suspect the cause of these fracture lines may be due to over tightening the M4 blade bolt, or stress around the bolt’s hole from crash impact. Flying high power setup with these fracture is extremely dangerous, at worse case could result in midair detachment of blade grips. To improve on structural integrity of these grips, we have developed and tested a new design with thicker area. The new grips greatly increase the overall rigidity and safety of the head. We are sending these New grips to you (2 new main grips, 2 M4x27 blade bolts per kit) and please return all the parts H60003 to replace. We sincerely apologize not catching this issue during product testing, and the inconvenience this may have caused our fellow flyers. Your understanding and continued support is greatly appreciated. We recommend that all T-Rex 600 be grounded regardless of the power system being used. For safety reasons do not fly the helicopter until the blade grips have been replaced with new design. ===============
T-REX 600 Problem
